Where have the nipples gone!
Testing6790Testing6790 Posts: 1,091
Slightly confusing, I was working on a character and was just doing the final tweeks and noticed that the only dial I have for nipples is the diameter one. The evolution body morphs have many more, I know, I've used them! But they are gone... Is this because I'm using DS4.5?
  • Testing6790Testing6790 Posts: 1,091
    Actually, I'm missing a lot of my morphs now that I think about it... I reinstalled them and nothing changed.
  • Miss Bad WolfMiss Bad Wolf Posts: 17,392
    I guess you are talking about Genesis?
  • frank0314frank0314 Posts: 10,702
    If you suspect it may be a 4.5 issue then maybe pop over and ask in the release thread here http://www.daz3d.com/forums/discussion/1900/
    Yes Genesis. And I don't suspect anything, I just have noticed that every weird thing that happens tends to be 4.5 still not supporting everything
    I personally haven't tried it yet. I need the plug-ins to work for development. So I'm in the dark when it comes to what is or isn't working. Sorry.
  • Richard HaseltineRichard Haseltine Posts: 43,316
    Where are you looking? There's an error in the current packages for the morphs - they don't have regions correctly assigned. DS4.0 was showing in the Shaping pane, in most situations, but they've dealt with the exceptions in 4.5 by making the pane behave as it should and therefore not show the morphs. They are still available in the Parameters pane, however.
    Thanks, Richard! That's exactly the issue I was having
  • RCDescheneRCDeschene Posts: 2,722
    Wait, are you saying that they were never even meant to be seen in the Shaping panel to begin with? :ohh:
    Not quite. They were meant to show on the Shaping pane, but they weren't set up correctly to do so and this wasn't noticed (presumably) because there was a compensating bug in the Shaping pane. The DS bug has now been fixed, so we need a content update to make the morphs behave as they should for the right reason instead of for the wrong reason, as they were in DS 4.0.
  • BarubaryBarubary Posts: 1,120
    Balancing one bug with another, that's how we roll in DAZland :D
