Digital Art Zone
DETATCH/ATTACH POLYS in the UV UNFOLD
Posted: 21 June 2012 02:55 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2010-09-22
I know you can DETACH POLYS in the UV UNFOLD area , BUT can you ATTACH polies there?
Profile
Posted: 22 June 2012 06:07 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI Rich smile
The UV detach polygons is different from the Modelling function “Detach polygons” which actually separates the mesh at that point.
The UV Version doesn’t. so there’s no need to attach them. they’re still attached.
If you apply a different mapping type, it will effect the entire model.
It’s like the Seams and Pins for UV unfolding,. It only effects the UV View of the model, so if you change the seams or change the mapping type it all goes back to normal.
Hope it helps smile
Profile
Posted: 22 June 2012 06:21 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2010-09-22
WOW YOUR KIDDING! That I did not know and that is great
Profile
