Digital Art Zone
3D Delight very slow on 64bit
Posted: 20 June 2012 04:48 PM   [ Ignore ]
New Member
Joined  2004-04-15
Hi—
I love the quality output of DAZ 3D, but I hate how slow it is.
Is there a frame count during rendering I am not aware of so I kinda of know how long I have left?
All I see if a spinning circle with no idea where I am or if I should have just rendered images.
I started a 405 frame 100 x 75 at low quality this morning around 10am and its now 3:44pm and it is still running.
I have an i7 with 8Gb of ram, 1Tb disk, ATI 6700 with 1Gb ram under Windows 7.
It sure would be nice if there was a “render farm” app that ran independent of DAZ and I’m not talking about the Renderman at Pixar.
Also, can you close the main app window and it will still render in the background?
cheese
Thanks! Newbie
No crashes with RC 4.5:-)
Profile
Posted: 20 June 2012 06:38 PM   [ Ignore ]   [ # 1 ]
Power Member
RankRankRank
Joined  2004-07-01
MangaFairy - 20 June 2012 04:48 PM
Hi—
cheese
Thanks! Newbie
frame rendering count is on the timeline - right hand side just before fps
your animation should be done long ago
did one 300 frames - default screen in about 12 mins.
Profile
Posted: 20 June 2012 09:13 PM   [ Ignore ]   [ # 2 ]
Active Member
RankRank
Joined  2012-02-04
I can’t talk to your animation render status, as I’ve never done it in Studio/3Delight.  (I do pretty much all my renders with Studio->Reality->LuxRender.)
But I can tell you that Studio does not let you render in the background from within Studio itself.  I suspect this is a licensing issue with the 3Delight render engine, since the folks that make 3Delight also sell it as a stand-alone renderer.  You can use the stand-alone version to render scenes outside of Studio, and it also supports network rendering.  However, the stand-alone 3Delight is extremely expensive; it is marketed towards professional studios working on commercial projects rather than 3D enthusiasts.  You need a license for each machine you wish to render on, and the license cost is also dependent on the number of CPU cores in each machine.  There is a free version as well, but it is limited to a single machine with only two cores, so is quite limited considering modern hardware.
LuxRender supports render farms with no additional fee, given that it is an open-source project.  However, LuxRender will introduce other issues for you if you were to try switching to it.  Materials are handled differently in Lux than in Studio, requiring conversion that, while not hard to do, has a learning curve to get good at.  And Lux, being a true unbiased raytracer, is also much slower at rendering than 3Delight.  The trade-off is that Lux generally produces better (meaning more realistic) results.  (You can make exceptionally realistic renders in 3Delight, but it requires a lot more work to set up than it does in Lux.)
 Signature
My deviantART Homepage
Profile
Posted: 21 June 2012 08:11 AM   [ Ignore ]   [ # 3 ]
New Member
Joined  2004-04-15
Thanks!
I thought it was taking too long.
I will look into LuxRender.
Thanks for the insightful replies!
...mf
smile
Profile
Posted: 21 June 2012 08:11 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2003-12-16
you can also try the 3delight forums over at 3delight.com
 Signature
Gravy to potatoes, Luke to Darth Vader, I’m a souped up sucker and I’ll see you all later
Profile
Posted: 24 February 2013 10:31 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2012-04-19
cwichura - 20 June 2012 09:13 PM
Well explained. You solved my doubts.
Profile
