Digital Art Zone
is there a plugin or tutorial for animated textures for cararra 8??
Posted: 20 June 2012 12:53 PM   [ Ignore ]
New Member
Joined  2012-04-17
im looking for a plugin & tutorial such like Animated Textures for Daz studio 3 but then for carrara 8 / 8 pro. i cant find it anywahere pls help
Profile
Posted: 20 June 2012 01:59 PM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
Carrara already can use animated textures and backgrounds, no plugin needed!
just open an avi, mov or sequenced image files (eg jpg, it will put up an open using window where you can choose sequenced jpg by clicking little arrow)
in the texture room or scene backdrop
you will have a start/finish slider you can position along the timeline under the texture, you can in the timeline keyframe start at beginning, finish at end and then click on the tweener and choose oscillate to make it loop a chosen number of times.
Image Attachments
 Signature
WARNING do not click tongue rolleye what will be seen if you do cannot be unseen.
Profile
Posted: 20 June 2012 02:56 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2012-04-17
well thank u very much wendy im testing thinks out. speak u laters and thanks for fast respons. tc see ya:-)
Profile
Posted: 22 June 2012 04:37 PM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2005-04-12
Wendy is quite correct about loading pre-animated textures, but you can also animate procedural textures in Carrara directly.  Set an initial texture, then move forward in the timeline and change some texture parameters - and it is done!
Profile
Posted: 22 June 2012 04:46 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2009-07-13
you can animate just about anything in Carrara if you wish!
vertex animation (changing the shape of a model) requires selecting all or some mesh, creating a morph target, editing and validating it but that even can be done.
only thing I have not been able to animate that I wish I could is brushing/restyling of hair and the replicators as in quantity and distribution.
 Signature
Profile
