Time stamp of the files installed by Install Manager.
JTroutJTrout Posts: 0
Hi,
I began to use Install Manager recently.
I am in trouble though this tool is very useful.
When the path of the contents library is except for the C drive, the time stamp of all the files (such as .duf, .obj) installed by Install Manager becomes installation time.
It becomes an actual proper time stamp when a contents library is a C drive (such as C:\Users\Public\Documents).
Even if Symbolic link or Junction are used, the result is the same.
I tried in the following two environments, and got the same result.
Windows8 64 bit
DAZStudio C:\Program Files\DAZ 3D\DAZStudio4
InstallManager C:\Program Files(x86)\DAZ3DIM1
Contents Library E:\user\DAZContents\Studio\DAZ Library
Windows7 32 bit
InstallManager C:\Program Files\DAZ3DIM1
Contents Library D:\user\DAZ\Studio\Library
The version of Install Manager is 1.0.1.75.
This is not a functional problem.
However, I would like to know an avoidance way because it may cause confusion in the management of a file.
Teach me a solution, please.
Kind regards,
  • Richard HaseltineRichard Haseltine Posts: 43,331
    I would suggest making a bug report for this - bugs.daz3d.com , which requires a separate log-in from the store and forum account.
  • FixmypcmikeFixmypcmike Posts: 17,300
    I'm not seeing this with 1.0.1.75, Win 7, installing outside C drive. Are you sure these were installed with .75 and not an earlier version, which did set the time stamp to the install time?
  • JTroutJTrout Posts: 0
    Thank you for the replies.
    As for the bug report, I think that I should check a little more carefully.
    As for the version, it is certain.
    After that......
    I found that when InstallManager is "run as an administrator", an actual proper time stamp is set up.
    I think that this behavior is strange though I use InstallManager in this method.
