Digital Art Zone
Problem with a dynamic skirt in Daz
Posted: 18 June 2012 02:30 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2007-06-16
Hi all,
I’m having a problem with a dynamic skirt in Daz.  I have a character that is falling to the floor.  The dynamic skirt conforms properly to V4.  But for some reason does not recognize the floor.  And sinks through it where it touches, pretty much ruining the effect.  I believe I have all the proper settings.  If I understand how this works correctly.  I’ve set everything in the scene so it should effect the dynamic cloth.  But it still sinks into the floor rather than colliding with it.
Any thoughts?
Thanks,
Dale
Profile
Posted: 18 June 2012 02:35 PM   [ Ignore ]   [ # 1 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
If your floor is a very low poly item it will not stop the dynamic items. The floor needs to have a pretty high poly count.
 Signature
My art on DeviantArt and my Project The Primitives a year in the life.
Father of the Stupid threads, find the Stupid you need here.
I may not be worth much but most people tell me my two cents were well spent
Profile
Posted: 18 June 2012 02:37 PM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  2009-08-05
Also if the item is too high polycount it will ignore:)
 Signature
My Daz Store
My Rendo Store
Latest Products
FaceWeight for Genesis
Toe Control for Genesis
Profile
Posted: 18 June 2012 02:43 PM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2005-10-16
If you don’t want to mess up your scene, find a high poly floor and make it transparent after placing it where the dress would collide with the floor.
 Signature
Gone.
Profile
Posted: 18 June 2012 03:05 PM   [ Ignore ]   [ # 4 ]
Moderator
Avatar
RankRankRankRank
Joined  2009-01-22
A primative Plane set to about 25 divisions at 6 M would also work. I’m pretty sure I’ve used that before. Just set opacity to 0 after you position it properly. Then just collide with the plane and anything else that needs it. You could stop the collision with the floor that does not work, that might even speed up the calculation time.
 Signature
Profile
Posted: 18 June 2012 03:29 PM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2007-06-16
Thanks,  I’ll give that a try
Dale
Profile
Posted: 18 June 2012 05:08 PM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
Rank
Joined  2003-10-09
Here’s the Little Black Dress with a 24 division plane, single distant light (Raytraced, 50% soft shadow). Works quite well.
Image Attachments
 Signature
Disrupting trains of thought since…. ohhh shiney!
Profile
