Can not install & I get this error message...
rwar21rwar21 Posts: 0
Install Manager cannot find a required path. The installer for "GoZ for DAZ Studio 4.5+ (Win 64-bit)" requires that the installed path for "DAZ Studio 4.5 (64-bit)" be defined. Make sure that a path for this application is present on the "Applications" page of the "Settings" dialog, then try again.
  • frank0314frank0314 Posts: 10,632
    It means the path to DAZ Studio needs to be showing in the applications tab. Did you happen to install DIM before installing DAZ Studio
  • crossmlkcrossmlk Posts: 0
    I'm having exactly the same problem. I did install the DIM before the program. Any ideas what I need to do to fix this?
  • VaskaniaVaskania Posts: 5,921
    If you can get into DIM, hit the cogwheel in the upper right > Applications tab. You can define your install paths in there.
    Do you know what path's I should use? I didn't download 32 bit since I have a 64 bit machine. The path for 32 bit appears to be to where the program tried to install. Should I change the 64 bit path to what is listed for 32 bit?
  • Richard HaseltineRichard Haseltine Posts: 42,688
    You will also need to specify where ZBrush is.
    If you didn't install the 32 bit version don't set its path - GoZ does not have to match the bit depth of ZBrush, it will work fine from the 64 bit DS
