how would i copy timeline portions, /and create an aniblock?
Noved1Noved1 Posts: 149
edited June 2013 in New Users
what method or program do i need to make my own ani-blocks out of a keyframed animation i have made?, also, is there a way to copy and paste entire stretches of timeline? thus duplicating a line of keyframes? i am trying to find a way to obtain the perfect loop. ---thank you
Post edited by Noved1 on
  • JaderailJaderail Posts: 0
    To Make AniBlocks you need AniMate+ or Animate2 full. It will allow you to convert any animation on the Daz time Line into a AniBlock. You can also Cut and edit them in AniMate. I will look up if KeyMate or GraphMate will allow clipping, I have them but not tried that.
  • Noved1Noved1 Posts: 149
    edited June 2013
    so using animate+ or full i can create an aniblock from my key-framed animation, then place them endlessly on the timeline? also, what is the distinction between AniMate+ or Animate2 full?
    p.s how do you always seem to answer so promptly? :D
    Animate+ was the one Before AniMate2, so 2 has more functions and editing abilities. And AniBlocks are only used in Animate or a Program that supports them, like Carrara. It has a Importer I believe.
