Can't close a curve?
philwebbphilwebb Posts: 0
edited December 1969 in Hexagon Discussion
I made a shape out of a mix of straight and then arc's added on to the ends as I went (select object add to end...) and when I select close curve it won't? What am I doing wrong?
Phil
UK
  • cdordonicdordoni Posts: 508
    You probably have a few separate lines and arcs. I know you indicated you had "connect to end of selected" on but you may still have unknowingly created more than one series. Drag a box around (or select all) the lines and arcs you want to close and use "Weld" in the vertex modeling tools.
    If you have drawn from the endpoints and used snapping this should work.
    If "Weld" does not work, you will have to determine where the pcs do not connect and do a "Target Weld" (vertex modeling tools) on those specific points. You may have to zoom in to see the 2 points that need to be welded.
  • Wee Dangerous JohnWee Dangerous John Posts: 918
    Phil, can you post a screen grab showing the curves and the properties tab ? That would make it easier to see what has gone wrong,
  • philwebbphilwebb Posts: 0
    Yes - I think I had another un-joined section....sorted now thank you
    Phil
