Digital Art Zone
V4++ morphs question
Posted: 17 June 2012 07:35 PM   [ Ignore ]
New Member
Joined  2005-09-08
I just bought the V4++ package. Do you not get the individual folders now, ie - just have to load them all?
thanks,
mystmaiden
Profile
Posted: 17 June 2012 08:22 PM   [ Ignore ]   [ # 1 ]
Active Member
RankRank
Joined  2010-02-14
When you load V4 in your scene you will be prompt whether or not you want to check them on as added-on dial morphs.
 Signature
“I’m sorry, I can’t hear you over the sound of how awesome I am!” ~ Brextor Ultimus
FORUM MEMBER POST RANKS
New Member = 0
Member = 25
Active Member = 250
Power Member = 1000
Addict = 2500
Profile
Posted: 17 June 2012 08:42 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2005-08-03
When you load V4, you should get the PowerLoader popup asking you which morph packs you want to load. If you’d rather load each morph 1 by 1, you can find them under Poser Format > My Library > Pose.
 Signature
Soft kitty, warm kitty, little ball of fur..
Previous Post Count: 2151 | @Deviantart
Howto: transmap brows on Genesis via V4/Daz/Blender
Profile
Posted: 18 June 2012 11:01 AM   [ Ignore ]   [ # 3 ]
New Member
Joined  2005-09-08
Thank you both for the replies. I forgot to add that I am using Poser 7. I’m not seeing all the individual poses, so maybe I didn’t dl the right packages,,,
What I do have under poses is a folder called ‘base’ with some expressions, eye poses, some heads, etc
Profile
Posted: 19 June 2012 01:39 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2006-08-26
In Poser 7, the individual morphs are in a folder named morphs ++. You should have installed ps_pe070 v4morphs.exe. The file path in Vista is C: Program files/e frontier/Poser 7. You will be asked to initialize. Click Ok.
The individual morphs ++  should be located Poses<Morph Injections<morphs ++. Individual morphs will be found in morphs ++ folder. Click on desired thumbnails for each morph you want to inject into V4.
Image Attachments
Profile
Posted: 19 June 2012 01:55 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2006-08-26
Click thumbnails to select desired morphs to inject into V4 figure.
Image Attachments
Profile
Posted: 19 June 2012 10:42 AM   [ Ignore ]   [ # 6 ]
New Member
Joined  2005-09-08
Thank you, Pixel8ted! The screenshots helped a lot. I reinstalled the file and its all sorted now. I’m not sure it I missed installing it on the first go or if it just had a hiccup somehow.
thanks again all,
mystmaiden
Profile
Posted: 19 June 2012 02:00 PM   [ Ignore ]   [ # 7 ]
Member
Avatar
Rank
Joined  2006-08-26
No problem.  When things don’t show up as they should, I usually manually go through the e frontier poser 7 application folder to look if there is a secondary runtime folder added where it shouldn’t be…usually in the library folder.  If there is a secondary runtime folder, I move it to where it should be.
Profile
