Digital Art Zone
How to Import Textures with Object
Posted: 17 June 2012 10:43 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2011-11-29
This is a reprise of a frequent question covered in a thread in the old forums.
When I try to import a Genesis figure with ordinary clothing it comes across as totally gray.  I can transfer it from DAZ Studio 4 to Hexagon 2.5 just fine (see figure), but then when I try to export it as either an .obj/.mat file pair or a .3ds file from Hexagon into Bryce 7.1 Pro, it comes across looking like the Silver Surfer (see figure).  This is using an iMac under 10.6.8.  What’s the right way to transfer a Genesis figure from DAZ Studio to Bryce?
MrWizard1024
Image Attachments
Profile
Posted: 17 June 2012 11:37 AM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  2003-10-09
Have you tried exporting a .OBJ from D|S,with the “Collect Maps” option checked? And be sure that the .OBJ/.MTL is in the same folder as the “Maps” folder that the “Collect Maps” creates.
Profile
Posted: 17 June 2012 03:53 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2011-11-29
dan whiteside - 17 June 2012 11:37 AM
Aha!  The trick was that in the OBJExportOptions dialog box, to Show Individual Settings, then to check Write Surfaces and Write Material Library, then choose radio button Collect Maps or Convert Maps for Bryce.
I do notice some pokethrough of the Genesis figure through the pants—normally, the DAZ Studio smoothing modifer handles that for me in DAZ Studio.  Is there an equivalent to the smoothing modifier in Bryce, or can that be handled only through postwork?
Many thanks, Dan
MrWizard1024
Profile
Posted: 19 October 2012 03:25 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2006-07-16
I have no problem with importing OBJ/MTL files into DS4 and getting them to render just fine without having to apply the texture.  However, if you are initially shocked by the gray-color imported figure, you may not even try to render the scene.
 Signature
Our Daz Store for great software products.
Our Product Catalog where you’re bound to find something useful.
Profile
Posted: 19 October 2012 03:38 PM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Having set your figure up in DS, save it and close DS. Open bryce use the Open DS icon on the top bar of Bryce (It’s the little Daz symbol) tell it where your DS is, and carry on from there to bring your figure into Bryce.
 Signature
Chohole’s Space        Neil’Vs Freebies and stuff        Bryce Rendering Challenge        Freebie Challenge
11915 was the number
Profile
Posted: 20 October 2012 11:57 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2003-10-09
“I do notice some poke-through of the Genesis figure through the pants—normally, the DAZ Studio smoothing modifier handles that for me in DAZ Studio.  Is there an equivalent to the smoothing modifier in Bryce, or can that be handled only through post work?”
Sorry I missed this - Bryce does have normals smoothing but that doesn’t change the geometry so you’ll still get the poke-through.
Couple things you can try:
If the body part is completely covered, just delete the body part in Bryce.
Sometimes you can make the clothing item slightly bigger, either by using the Edit Attributes dialog>size or with the Alt/Option key and the resize gadget.
Also sometimes you can simply moving the clothing item slightly forward or back.
I just had this problem with a Genesis figure and the Swim Wear 2 outfit. The image shows the poke-through and I the fixed version by moving it forward (Z)  only .2 BU.
Image Attachments
Profile
