Skin compatibility
PhiloppPhilopp Posts: 226
Hello,
if a skin is compatible to M3, or requires M3, can it also be used on M5?
Thanks for the answer.
P.
  • ChoholeChohole Posts: 27,028
    In the main Skins only for the generation they were made for,
    Gen 4 skins can be used on gen 5, if you use the relevant UV set, but Gen3 was done is such a radically diffrent way on the UV map that afaik there is no way they can be used.
  • BWSmanBWSman Posts: 0
    You would need to use Texture Converter 2 to convert the skin to M4 (or V4) and then apply it to Genesis.
  • PhiloppPhilopp Posts: 226
    edited June 2013
    Hello,
    at first thank you very much for the answer. And sorry for to be such a noob. Just so that I understand it thoroughly, the next question:
    If a hair or cloth is said to be compatible to M4, can I use it on M5 or on a Genesis figure?
    Thank you very much for your patience and for your help
    Greetings
    P.
    Post edited by Philopp on
