Digital Art Zone
1 of 4
1
Aiko 3 and Genesis
Posted: 16 June 2012 02:01 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2010-12-07
Aiko 3 seems to have been quite the phenomenon, theres so many wonderful(if you like anime) stuff for her that I dont find for Aiko 4, and the morph shapes are much closer to traditional anime in my opinion.
My question is, how much of this stuff works with Genesis?  If I get the Aiko 3 for Genesis will all the clothes, skin and hair for Aiko 3 work?  What about the morphs?  If I use Gen X will I be able to get the exact same facial morphs?  And what about the various eye morph products for Aiko 3, do those work for genesis?  Lastly will Melody at RDNA, the one used to create many animal heads, work for Genesis with the Aiko 3 morph since Melody was intended for Aiko 3?
Thanks in advance.
Profile
Posted: 16 June 2012 03:46 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2009-08-05
Aiko3 clothes work on Genesis. Hair yes. Morphs through Genx should work as good as gen4 transfers .No aiko3 or gen3 texure support (convert to aiko4/v4 via textureconverter2). So the only no go is textures, unless you convert them to gen4.
 Signature
My Daz Store
My Rendo Store
Latest Releases
Bend Morphs For Genesis\V5
Aging Morphs For Genesis
Profile
Posted: 16 June 2012 04:22 AM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  2004-04-14
I dont think Melody will work because its a whole different character that makes use of the Aiko3 body but has a completely different head.
 Signature
My DAZ3D Store
My Free Stuff
My Art @ DeviantART
Ships of the Line - MEGA THREAD
How to use the Poser Format Exporter - **Updated 2013-02-09**
Profile
Posted: 16 June 2012 09:18 AM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2003-12-06
No, the Melody morphs and textures can’t be transferred to Genesis because the different head makes it a different mesh with different UVMaps. I’d be very happy if someone were to figure out a way to do it, though, as I have a large (and boisterous!) crowd of Melody-based characters, and I’d love to be able to use some of the Genesis features on them.
Edit: And many of my Melody characters use the digitigrade legs. Has geometry swapping been fixed yet in D|S4, or is it still horribly broken?
 Signature
Gone to Vegas to play poker. Back when I run out of clothes.—Your Muse.
Profile
Posted: 16 June 2012 10:18 AM   [ Ignore ]   [ # 4 ]
Addict
RankRankRankRank
Joined  2004-07-21
SpottedKitty - 16 June 2012 09:18 AM
I think DS4 uses geografting which would allow the adding of digitgrade legs.
 Signature
Hello, Sweetie!
Profile
Posted: 16 June 2012 01:30 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2006-10-01
There are no Gen 3 UVs for Genesis. Texture Convertor should work as mentioned.
Aiko 3 clothes work if you have the Aiko 3 Iconic Shape.
http://www.daz3d.com/shop/a3-and-h3-shapes-for-genesis/
Morphs can be transfered with the Gen3 addon for GenX:
http://www.daz3d.com/shop/genx-addon-gen3-for-a3-and-h3/
But to get the morphs to look right you’d need the Iconic Shape.
 Signature
My works with DAZ Studio and stuff.
Simplified guide to Genesis content creation.
DSA Bulletin Board. Promote your products here.
Profile
Posted: 17 June 2012 02:07 AM   [ Ignore ]   [ # 6 ]
Active Member
RankRank
Joined  2010-02-14
Oh God, do I wish Genesis had Gen 3 Texture capabilities as well! Like everyone says, 3D Universe has the Texture Converter 2 add-on that supposedly does the trick, however, I also heard from multiple users of it that there is occasionally stretching, which puts a bit of a knot in my stomach as I debate whether or not I should go through the trouble of making the investment…
But yeah, if you get it, let me know how it works.
 Signature
“I’m sorry, I can’t hear you over the sound of how awesome I am!” ~ Brextor Ultimus
FORUM MEMBER POST RANKS
New Member = 0
Member = 25
Active Member = 250
Power Member = 1000
Addict = 2500
Profile
Posted: 17 June 2012 02:09 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
There is always DAZ’s 30-day money back option if the texture converter doesn’t produce the results you want… smile
In theory if the map stretches in order to fit to a V4 map, using the V3 shape should “un-stretch” it again as you’re going back to the original geometry shape (ish) for that texture. It’d be interesting to try, anyway smile
Cheers,
Cliff
 Signature
Cliff’s Store
Profile
Posted: 17 June 2012 02:35 AM   [ Ignore ]   [ # 8 ]
Active Member
RankRank
Joined  2010-02-14
Cliff Bowman - 17 June 2012 02:09 AM
Cheers,
Cliff
Granted that can always be simply done, but what if I were to use a Gen 3 Texture on a non-Gen 3 or mixed character Genesis figure?
 Signature
New Member = 0
Member = 25
Active Member = 250
Power Member = 1000
Addict = 2500
Profile
Posted: 17 June 2012 02:43 AM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
RCDeschene - 17 June 2012 02:35 AM
The more the character’s shape deviates from the shape the texture was created for, the greater the chance of smearing/stretching issues :(
Somewhere there’ll be a “tipping point” where the resultant quality is insufficient.
Cheers,
Cliff
 Signature
Cliff’s Store
Profile
Posted: 17 June 2012 02:44 AM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  2003-10-09
Just a couple of points:
Texture converter works very well for organic patterns like furries skins and VERY badly for clothing style 2nd skins.
As far as the mesh stretching and unstretching, the algorithms used by Texture Converter and Genesis/Studio are very unlikely to be reciprocal. Its far more likely that the double conversion will make things worse rather than better
Profile
Posted: 17 June 2012 10:48 PM   [ Ignore ]   [ # 11 ]
Active Member
RankRank
Joined  2010-02-14
Hence why DAZ should really consider adding Gen 3 UV support for Genesis themselves instead of having me buy a program that I’ll most likely just end up returning. I mean no disrespect to 3D Universe when I say this, either…
 Signature
New Member = 0
Member = 25
Active Member = 250
Power Member = 1000
Addict = 2500
Profile
Posted: 18 June 2012 01:08 AM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Agreed. I wonder how much effort it would be to do? Probably quite considerable… hm.
 Signature
Cliff’s Store
Profile
Posted: 18 June 2012 05:36 AM   [ Ignore ]   [ # 13 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
The problem is that there are surfaces on Genesis that are split between two surfaces, on different maps, in the Gen 3 mapping. Alternative UVs are a surface proeprty, I don’t think they can split a UV region in two as would be needed to apply the Gen 3 maps directly.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 18 June 2012 06:37 AM   [ Ignore ]   [ # 14 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Richard Haseltine - 18 June 2012 05:36 AM
Not to mention that that would be ANOTHER step away from Poser compatibility for Genesis.  Hitting a moving target is extremely hard.  Changing the Genesis base for something like that could hurt any fledgling efforts by “others” to get Genesis into less capable software.
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 18 June 2012 07:12 AM   [ Ignore ]   [ # 15 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
Kendall Sears - 18 June 2012 06:37 AM
Kendall
I suspect you’ll find that’s already been done - existing UV maps aren’t all consistent like you’d find on the Gen4 or the Gen3 figures - they are cut up differently. Even have different UV vertex counts IIRC.
 Signature
Cliff’s Store
Profile
1 of 4
1
