Duplicate Formulas Error Solved! Thank you Bejaymac!
JohnDelaquioxJohnDelaquiox Posts: 1,133
edited May 2013 in The Commons
IS there a quick and dirty way to fix the Duplicate Formulas Error
First two errors are due to missing morphs, the Joequick morphs are looking for morphs from other products and you either don’t have them or don’t have them installed.
Thank you, Thank you Bejaymac
The duplicate formula errors are easy enough to fix, DS4.5 or 4.6 will do it for you.
1) load Genesis into an empty scene, you’ll get the error message, just click it to carry on.
2) find the offending morph(s) in the Parameters tab, in this case it Actor/Universal/Fantasy SciFi and it’s the HFS_Shapes_Head01 morph.
3) Dial the morph to make sure it works and then zero it again.
4) at one end of the dial you’ll see a little “cog”, click on it and in the little menu that opens click on Parameter settings.
5) in the new window that has just opened you will see a Color A & a Color B, click on Color B to open the color picker.
6) Set the color to 254, 254, 254 and click OK.
7) Click “Accept” at the bottom of the Parameter Settings window.
8) After that window closes go “File > Save As > Support Asset > Save Modified Assets”.
DS will do a quick scan of the figure and open a small window that should only have the one file listed, accept it and DS will replace the old file with a new updated one.
You can now clear the scene and Genesis will no longer give you that error from that morph, you might still get it from others, but you now know how to fix it.
Post edited by JohnDelaquiox on
  • lface8lface8 Posts: 91
    This thread may be what you're looking for:
    http://www.daz3d.com/forums/discussion/740/
  • JohnDelaquioxJohnDelaquiox Posts: 1,133
    Unfortunately no.
    This is a log, the files listed are ones I have installed on my own from a Rar file and I have checked to see if the files are duplicated or on multiple locations and they are not
    WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/Mallenlane/Takashi/FBMTakashi.dsf#FBMTakashi?value in file : /data/DAZ 3D/Genesis/Base/Morphs/Joequick/Duckie/DuckTakashiAdj.dsf
    WARNING: fileinput\dzassetdaz.cpp(5127): Could not find target property for formula: Genesis:/data/DAZ 3D/Genesis/Base/Morphs/smay/MrHyde/FBMMrHyde.dsf#FBMMrHyde?value in file : /data/DAZ 3D/Genesis/Base/Morphs/Joequick/Duckie/DuckHydeAdj.dsf
    WARNING: fileinput\dzassetdaz.cpp(5301): Duplicate formula found linking xOrigin & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5301): Duplicate formula found linking yOrigin & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5301): Duplicate formula found linking xEnd & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5301): Duplicate formula found linking yEnd & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5301): Duplicate formula found linking xOrientation & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5301): Duplicate formula found linking yOrientation & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    WARNING: fileinput\dzassetdaz.cpp(5301): Duplicate formula found linking zOrientation & Value in /data/DAZ 3D/Genesis/Base/Morphs/HellFishStudios/HFS Shapes/HFS_Shapes_Head01.dsf.
    File loaded in 0 min 7.5 sec.
    Loaded file: Genesis.duf
  • Richard HaseltineRichard Haseltine Posts: 42,688
    No, that's for duplicate IDs. Duplicate Formulas is an older issue which requires getting newer copies of the morphs from your account or from the Install Manager (if you have the Genesis Evolution Expressions you need to uninstall those first). This has an entry in the FAQ, linked in my signature.
    edited May 2013
    I did that and still nothing
    what would happen if I deleted the genesis duf file
  • KatteyKattey Posts: 2,899
    Those morphs aren't from DAZ3D and I really doubt the vendor will update them. Is there a way to fix them ourselves?
    I really can't see how the formulas could have duplicated?
    It's a bug in very old versions of DS4, I think someone did discuss a way of fixing that set recently but I'm not sure.
    I have the latest version of DS4 and the latest of all the bases.
  • BejaymacBejaymac Posts: 1,205
    First two errors are due to missing morphs, the Joequick morphs are looking for morphs from other products and you either don't have them or don't have them installed.
    1) load Genesis into an empty scene, you'll get the error message, just click it to carry on.
    2) find the offending morph(s) in the Parameters tab, in this case it Actor/Universal/Fantasy SciFi and it's the HFS_Shapes_Head01 morph.
    4) at one end of the dial you'll see a little "cog", click on it and in the little menu that opens click on Parameter settings.
    7) Click "Accept" at the bottom of the Parameter Settings window.
    8) After that window closes go "File > Save As > Support Asset > Save Modified Assets".
    Awesome Bejaymac, Thank you so much!
  • Daily_DoodlerDaily_Doodler Posts: 34
    Worked for me, nice one!
    A c-c-color? All this time it was error for a color of slider? O_o
    Bejaymac, thank you very much - it worked beautifully for me! No more annoyance!
  • JaderailJaderail Posts: 0
    No it's not a color, but you must change something to save as Updated, the Save fixes it not the color change.
    Ah! Got it, thanks!
  • CougashikaCougashika Posts: 0
    So I load Genesis into the scene, and an error message ... does not appear. Oh, well, carry on.
    Okay, so I find the morph in the actors tab...
    Wups, it won't load from the content library. It won't load onto Genesis at all.
    Dial the morph to make sure it works? I can't load the morph! It doesn't work.
    The morph does not list in the Parameter, so there is no dial or cog...
    Needless to say none of the other items from 5) to 8) happen either.
    I'm not trying to act stupid. This is my first time doing morphs in DS 4.5, and if I buy a product I expect to be able to use that product after downloading.
  • CitizenMCitizenM Posts: 17
    Thank you so much for this solution! Totally improves my Studio experience! Thank you, thank you, thank you!
  • edited January 2015
    Been having this error for months... thanks bejaymac.
    Post edited by wendymacho629_0e5efa8244 on
  • vrba79vrba79 Posts: 161
    Wow! You are some kind of sorcerer! This has always annoyed the hell out of me!
    Hi, how can you know which morphs have the problems and need to be adjusted?
  • You just need to open your log and read the most recent additions. Mine seems to go back 11 days or so. Just scroll to the bottom.
    Thankyou Bejaymac, thank you. I was about to start pulling out the few hairs I had left =)
  • worked!!!
    Thanks, was a pretty easy way to get rid of that annoying message.
    Recommendation: First "Help/troubleshooting/View log file..." and delete+save ALL the log, then open Gen figure and start the procedure... it's quite easier to follow the log (in my case, some log lines where not ordered by date)
  • On Windows machines look for this path:
    C:\Users\login name\AppData\Roaming\DAZ 3D\Studio4
    You should find a log.txt file that can be easily opened in anything, even the basic Notepad.  Ctrl-A -> Delete -> Save will flush the logfile to a zero-byte blank at any time, so the next action (presumably the one with the errors) is the first thing logged.
    laugh
  • Vanger ChevaneVanger Chevane Posts: 2
    edited December 2017
    Also, with the file manage at the proper location for the Log.txt, it can be reloaded & cleared at any time with any text editor you prefer without needing to dig thru Studio to do it.
    Save As should also show you the correct path to the log file.  a single left click in the blank space right of the "address" should give you a copyable link to drop into the file manager.
    Post edited by Vanger Chevane on
