Shader Mixing Challenge
FractalDimensiaFractalDimensia Posts: 0
edited May 2013 in Carrara Discussion
I am stuck on a (simple but not easy) problem, and thought I'd take it to the Carrara community for some advice or suggestions. Maybe someone else has already solved this problem, and it's much easier than I am thinking it is. Or it could be because I am still a Carrara noob....
1) I need to be able to mix two textures (texture maps) on a sphere, with 50% of each map showing on each side or face.
2) I need the region between the two sides to slowly transitioning to the other (i.e., no abruptly changes). I also need to be able to adjust the width of the region of transition.
See the attached pic as an illustration.
So far, this is easy to do. However,
3) I also need to be able to rotate the texture maps in the shader (or rotate the blender). That is, I want to be able to select which half of the maps are visible. The rotation needs to occur smoothly, so I want to be able to define the amount of shifting in the map by degrees.
4) The two texture maps overlay precisely, so I need the two texture maps to rotate simultaneously. A 27 degree rotation in the first should mean a 27 degree rotation in the second.
5) I need to be able to animate the results, so manually shifting the two textures is not a viable solution.
What I have tried so far:
- Mixing two textures (as in the image attached) is straight forward, and there are several ways to do this. But it doesn't help with #3 to #5 above.
- Creating two separate spheres slightly askew and rotating them simultaneously works to some degree, but the region between the two textures changes too abruptly, and does not provide a realistic result, even in attempting only a minute variation in their centers.
I've also already considered creating an AVI file to use as the blender, with black/white regions slowly shifting horizontally. But this would be time intensive, and limits me in defining the rate of map rotation.
One more piece of information that might be useful: Light only shines on one of the 2 texture maps. The other map is self-illuminated.
Suggestions anyone? Am I missing an obvious and simple solution?
Thanks in advance for your help!
1390 x 719 - 189K
Post edited by FractalDimensia on
  • JoeMamma2000JoeMamma2000 Posts: 2,615
    Did you try the UV Transform operator?
    Also I thought there was some way to link a texture to, say, a null object (target helper) and make it follow the null. Or maybe that's not in Carrara, but some other app...
  • head waxhead wax Posts: 5,619
    Hi Fractal
    also there are these
    http://www.des-web.net/html/shoestring_shaders.html
    Location, Proximity or Multipass manager might help your quest.
  • FractalDimensiaFractalDimensia Posts: 0
    Joe, can you be more specific in how I could use the UV Transform in an animation? Thanks!
    edited May 2013
    The Environment shader has a rotation control. Set the Orientation tab to 100% influence. Set the other tabs to 0% influence.
    The Direction parameter rotates the shader.
    The Blend parameter sets the blend zone.
    963 x 453 - 133K
    Post edited by wetcircuit on
    Well, I suppose you could keyframe the values you want to change over the course of the animation..... :bug:
    Holly, your suggestion did the trick! I did a test render it was precisely what I needed.
    Many thanks to you, Joe, and Head for your suggestions!
