Different shading for objects
3dOutlaw3dOutlaw Posts: 1,545
edited December 1969 in Hexagon Discussion
How would I make the locked object I am modeling around, be a different shader than the object I am modelling? (i.e. smooth solid object under, wireframe for the one I am tweaking, so I can see the object under it)
  • patience55patience55 Posts: 6,981
    You'll have to unlock it and change its colour(s), then lock it again.
  • stem_athomestem_athome Posts: 350
    edited May 2013
    On the bottom menu, enable "Activates the transparent display of sub-objects". When then in sub_object selection(poly/edge vertex selection mode), the selected object will become transparent.
    You can change the amount the object will become transparent in "Edit-> Preference editor->" "3d display-> Selection"
    1215 x 803 - 195K
    Post edited by stem_athome on
  • 3dOutlaw3dOutlaw Posts: 1,545
    Very good, I will try that, thank you!
