Digital Art Zone
2 of 9
2
Problems with older products (installer doesn`t work)
Posted: 26 May 2012 07:17 AM   [ Ignore ]   [ # 16 ]
New Member
Avatar
Joined  2007-10-25
I don’t know what a “hex editor” is, so I wouldn’t even begin to play around with it.
These older items, will they be fixed at some point? I massive undertaking, I understand as there would be thousands of items that would need fixing, but is that the only way that these .exe files will work; be patient until the .exe is updated?
Profile
Posted: 26 May 2012 08:16 AM   [ Ignore ]   [ # 17 ]
New Member
Joined  2011-08-11
I cant install them on my computer(win7), is it possible to get the files sent in folders(and not the installer file?)
I have tried to install in other modes to, but it doesnt help.
( I should have asked in the help section, but nothing there seem to work raspberry )
Profile
Posted: 26 May 2012 08:47 AM   [ Ignore ]   [ # 18 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
There is a problem with older installers not downloading properly—if you are comfortable editing binary files, a fix was posted involving removing spurious characters at the end of the file.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 26 May 2012 09:39 AM   [ Ignore ]   [ # 19 ]
New Member
Avatar
Joined  2003-10-09
I assume the problem with the old installers is a web server configuration issue. The actual installers haven’t changed from the way they were when they worked, they just have an error message appended to them. They just have to fix the script that serves the file.
The newer installers not running well on some people’s systems might be a permissions thing, I don’t know. The proposed zip file system will fix that.
Profile
Posted: 26 May 2012 10:50 AM   [ Ignore ]   [ # 20 ]
New Member
Joined  2011-08-11
I dont know how to edit binary files, but could try.. Where is that fix?
Shouldnt it be a warning on the old files that dont work properly? I dont want to buy things that dont work raspberry
Is there any possibility to get these files in folders? Seems like a good solution for me, offer old product without the installer to aviod these problems.
Profile
Posted: 26 May 2012 11:16 AM   [ Ignore ]   [ # 21 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
http://www.daz3d.com/forums/viewthread/217/#2521
I know DAZ is switching to Zips for all products, but I don’t know when that will take effect.  Since Monday is a holiday in the US, I’m not sure what will get fixed before Tuesday.
 Signature
Products In Zips
Profile
Posted: 26 May 2012 01:29 PM   [ Ignore ]   [ # 22 ]
New Member
Avatar
Joined  2007-09-05
I just wanted to add my thanks as well for that great and simple tip, Ruekaka.  grin
I used HxD Hex Editor from CNET’s Download.com and followed your screenshots to remove the extra bytes at the end of my two installers.  Great job!
Profile
Posted: 26 May 2012 03:58 PM   [ Ignore ]   [ # 23 ]
Active Member
Avatar
RankRank
Joined  2003-10-09
If your installer doesn’t work, you can always try downloading it a second time.  While it doesn’t happen to me offen, occasionally a file gets corrupted during download for whatever reason, and redownloading it often fixes the problem.
Profile
Posted: 26 May 2012 05:22 PM   [ Ignore ]   [ # 24 ]
Active Member
Avatar
RankRank
Joined  2010-06-29
Studiohelgeland - 26 May 2012 10:50 AM
I am no expert in things like that but I have done it like it is posted some posts above smile and it worked quite well and was easy.
if you have an hex editor (there are some free products out there) start the hex editor and open the file (the installer) than the hex code appears on the left and on the right another list, scroll down until you are at the line you read “fatal error” mark the text on the right side like it is posted above and than delte it smile save the edited version as “save as”... or just “save”
go to your folder were you have the edited installer and start it and it should work.
 Signature  Samples of my renders by cosmo
Every day is your day - not the day of other people - So live your life, not the lifes of others and enjoy it
Profile
Posted: 26 May 2012 05:29 PM   [ Ignore ]   [ # 25 ]
Active Member
Avatar
RankRank
Joined  2010-06-29
Sean Riesch - 26 May 2012 03:58 PM
well related to the old installers you can download them much as you can, the installer will not work it is a known problem and as daz said, has something to do with the new site.
all you can do is to use a hex editor as it is written in the post at page 1 of this thread.
 Signature
Profile
Posted: 26 May 2012 05:36 PM   [ Ignore ]   [ # 26 ]
New Member
Joined  2011-08-11
Greate smile smile smile It was an easy job when I followed the instructions and used the program that is linked to here smile
My files work now. Tnx alot for the help smile
Profile
Posted: 26 May 2012 05:36 PM   [ Ignore ]   [ # 27 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
I have written a small utility to make these installers work again by stripping off the bad appendage.  Is any interested in it?
Kendall
Image Attachments
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 27 May 2012 10:20 AM   [ Ignore ]   [ # 28 ]
New Member
Joined  2007-10-04
I opened up the Wildwood flirts in a hex editor and screenshot-ed the last bit of the code, what do I need to delete to make this .exe work
Profile
Posted: 27 May 2012 12:37 PM   [ Ignore ]   [ # 29 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Sapphire587, I’ve merged your thread with another on the issue - if you scroll up theer are instructions, and Kendall has a fix utility.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 27 May 2012 03:57 PM   [ Ignore ]   [ # 30 ]
New Member
Joined  2006-08-26
Hi,
I’m new to this community.
I have installed DazStudio4 onto my other hhd due to my main drive almost full.  I own a PC, Vista 64bit machine.
I brought SFSC_Construction set and when i downloaded it and ran the Exe it seemed to load something and then nothing, no setup window or anything.
Any ideas as to why?
Thanks for your help
Darian
Profile
2 of 9
2
