Start DAZ studio stops the DAZ CMS
cobblerzcobblerz Posts: 0
As of this morning all of my Smart Content and Categories had disappeared. I have checked a number of forums to try and find a solution but, I have not got a working solution.
I have uninstalled studio and CMS and reinstalled again.
I have checked to see if the CMS service is running and started it again, but when i start Studio the CMS stops. I have had task manager open and seen the start change as soon as i start Studio.
Any ideas?
  • FixmypcmikeFixmypcmike Posts: 17,300
    Fixing a corrupt CMS index (letting DS rebuild it)
    http://www.daz3d.com/forums/viewreply/314635/
    - Usually fixes "unstable" CMS issues
  • cobblerzcobblerz Posts: 0
    hi Mike,
    Tried all that was mentioned on the other thread, but still no joy.
    My CMS folder did not contain a database folder as the server stops before Studio starts so there is no chance of bulding one.
    my last vlog was
    Fri May 3 2013 14:37:01.682000 ContentManagementServer (4.8, Kernel 4.8 )
    Licence license_emb_4422548148518942 is registered to DAZ3D.
    Valid until 9999-12-31. Subscription valid until 2013-02-08.
    Maximum number of connections: 5
    Fri May 3 2013 14:37:01.729000 (TID 5000): VProject facilities are disabled since no appropriate license found
    Fri May 3 2013 14:37:01.729000 (TID 5000): Server started
    Fri May 3 2013 14:37:01.729000 (TID 5000): Non-secure port: 27997
    any ideas?
    OK I have managed to resolve this, my databases folder was in another directory. I have removed this, restarted the CMserver, reloaded Studio and am in the process of rebuilding the metadata, things have started to appear in the smart Content pane, so I am assuming it is working.
    Thank you for your help.
    Regards
    OK Correction it was workng OK but now it is not, again. The problem this time is that the CMServer is running but the vlog message is as follows:
    Fri May 3 2013 17:09:47.471000 ContentManagementServer (4.8, Kernel 4.8 )
    Fri May 3 2013 17:09:48.813000 (TID 2412): VProject facilities are disabled since no appropriate license found
    Fri May 3 2013 17:09:48.813000 (TID 2412): Server started
    Fri May 3 2013 17:09:48.813000 (TID 2412): Non-secure port: 27997
    Any ideas?
