I need your input
TrishTrish Posts: 2,625
edited May 2013 in Bryce Discussion
on procedural textures
Post edited by Trish on
  • ManOfSteelManOfSteel Posts: 14
    And your question is?
  • HoroHoro Posts: 5,555
    Quite challenging to give a precise answer here. :-)
  • ChoholeChohole Posts: 27,020
    Yeah presumably you want more than
    A procedural texture is a computer-generated image created using an algorithm intended to create a realistic representation of natural elements such as wood, marble, granite, metal, stone, and others.
    Usually, the natural look of the rendered result is achieved by the usage of fractal noise and turbulence functions. These functions are used as a numerical representation of the “randomness” found in nature.
    If you've got nothing else to do, you can read this 84 page document http://www.horo.ch/docs/mine/pdf/DTE.pdf (23 MB) which is quite exhaustive and supplements David's 17 videos (4 hours) on the subject.
  • TapiocaTundraTapiocaTundra Posts: 268
    @ bullit35744 who doesn't :)
    @ Horro thanks for that link, you certainly have put a lot of work into that .pdf and it helps me to understand a little more about the different Voroni noise types I have been looking at, eighteen in all, this seems a little excessive to me, is there any more info about them, and their uses, for example I would like to know why voroni distance 1 has it"s name, what is "Distance" referring to ?
  • TrishTrish Posts: 2,625
    just wanted to get a discussion about how to make them in bryce and how to use them. there is a nice new image on bryce5.com with a tree with bark and on parts of the tree are moss and I am really lost on the subject of how something like this could be made.....thanks Horo I will check out your pdf and the other links....Trish
    Sounds good, have you got a link handy to taht image
    Please.
  • David BrinnenDavid Brinnen Posts: 3,096
    Probably this one. http://www.bryce5.com/details.php?image_id=5322&sessionid=4f8044f94b5836bc0b3bf0539908b7e3
    Alexey is a brilliant landscape artist, maybe Pam could work her charms on him and coax him over here. Either the charms or the big stick...
    edited May 2013
    First we need Galleries.
    That is a superb image. My attempts at moss are pathetic compared to that
    Hmm, did I remember to mention that we need Galleries. :coolsmirk:
    Post edited by Chohole on
    edited May 2013
    yes David has it right that is the image I was speaking of.....to be able to do that or maybe put moss on bricks in certain places would really be neat.....but most of the language and math is over my head I'm afraid...Trish
    There are several possibilities. You can use two texture channels in the DTE and use Blend Orientation, which is the simplest method. Or you can copy the object (wall, tree trunk, whatever), give the copy another material (perhaps with transparency) then either move the copied object slightly out of the primary one or make it slightly larger. Tip: if you start experimenting to understand how these things work, use just single simple colours. When you see what happens, go for the fancy things.
