Digital Art Zone
In search for a good Geo-Grafting Tutorial
Posted: 23 May 2012 05:58 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2008-02-08
Is there any Geo-Grafting tutorial out there that has a documented step by step instruction on how to use it?
I searched in the old forum but the one tutorial I found is illustrated by images which can’t be viewed in the archive.
I am really banging my head as I don’t get Geo-Grafting to work. Also on the forums there are several different instructions, which works, which not is not clear to me.
Many thanks!
Profile
Posted: 24 May 2012 06:03 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
You can view the images with a bit of a fiddle - paste the url from the HTML, starting with postimages and ending with the extension (.jpg or whatever) after http://forumarchive.daz3d.com/ to get a link that will show the image.
Are you wanting to create new items or use exsting items?
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 24 May 2012 12:14 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2008-02-08
Thank you, I try to fiddle the images grin
I made new items. I followed every step as good as I could. All vertices of my grafted items are exactly lined up with the Genesis vertices where it will be attached.
Also I marked the faces of the grafted item as “grafted faces” from the assignment menu and on the Genesis side the faces that should be hidden. I also tried a version of a tutorial that said on Genesis the grafted assignment need to be declared as well. Then I saved the grafted item after fitting it to Genesis. But even with a reload of Studio it does not do anything. The DSF files at least shows it has assignment and hidden faces included. I am now out of ideas what I am doing wrong.
Thanks for your help.
Profile
Posted: 24 May 2012 01:31 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Is the item fitted to Genesis when you reload it?
 Signature
Profile
Posted: 25 May 2012 01:59 AM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  2008-02-08
Yes it is fitted. I also checked by unfitting and refitting it. Grafted items by others do work. I checked to make sure it isn’t something like that.
Profile
Posted: 25 May 2012 08:13 AM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Did you actually snap the vertices of your item to those of Genesis, or did you rely on visual alignment? Nothing is leaping out from your description as wrong.
 Signature
Profile
Posted: 25 May 2012 05:19 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2008-02-08
Hi Richard, I snaped every vertex of the graft item to the acording vertex of genesis.
i even did a test detaching one part of genesis and use it as graft item.
Profile
