Digital Art Zone
1 of 2
1
Geppetto DS4
Posted: 13 June 2012 03:21 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2007-09-12
It’s for 4.5 64bit… However the environment is set up also to compile 32bit. smile ok… I am going to make something good out of it. Expect a release soon (and access to source code of course):
 Signature
Favourite Figure: Victoria 5
My Art Gallery: http://mattiascibien.azurewebsites.net/3d-art/
Developer of CameraReady for DAZ Studio (thesis project).
Profile
Posted: 13 June 2012 04:34 PM   [ Ignore ]   [ # 3 ]
Member
Rank
Joined  2011-03-31
More animation tools for DS4 are always welcome.
Profile
Posted: 13 June 2012 04:44 PM   [ Ignore ]   [ # 4 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Was it originally released with permission to modify?
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 13 June 2012 07:31 PM   [ Ignore ]   [ # 5 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
The OP did say GPL, don’t know what version, but I believe that allows modification and distribution as long as it continues to be GPL licensed.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 14 June 2012 07:16 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2007-09-12
GPLv3 and obviously mine will be released as GPLv3 for sure.
 Signature
Profile
Posted: 14 June 2012 08:34 AM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Thanks for confirming, I couldn’t recall.
 Signature
Profile
Posted: 14 June 2012 08:40 AM   [ Ignore ]   [ # 8 ]
Power Member
RankRankRank
Joined  2004-07-01
lot of people waiting for this - all the best
Profile
Posted: 15 June 2012 08:21 PM   [ Ignore ]   [ # 9 ]
New Member
Avatar
Joined  2008-07-19
gravity0 - 14 June 2012 07:16 AM
Hi all,
I’m the original author of Geppetto, and yes absolutely you may modify it. It was my hope that someone would pick it up and work on it. Unfortunately I’m unable to continue developing it myself due to a family illness, but I’m very happy to see that someone else has taken an interest in it.
Best regards,
Artemia
Profile
Posted: 19 June 2012 03:40 AM   [ Ignore ]   [ # 10 ]
New Member
Joined  2012-02-25
I am definitely interested and will keep an eye on your thread. Thank you for your effort and I hope the porting goes smoothly!
Profile
Posted: 19 June 2012 09:50 AM   [ Ignore ]   [ # 11 ]
Member
Avatar
Rank
Joined  2012-05-25
where can i download Geppetto for ds4.5 64 bit? red face
i need this!
dazstudio is not applicable to do animation. mad
and animate plugin is only useful if you use the motions made for animate. ohh
Profile
Posted: 22 June 2012 11:10 AM   [ Ignore ]   [ # 12 ]
Member
Avatar
Rank
Joined  2012-05-25
gravity0 - 13 June 2012 03:21 PM
can you create some IK / FK switch setup with it?
Profile
Posted: 22 June 2012 11:22 AM   [ Ignore ]   [ # 13 ]
Member
Avatar
Rank
Joined  2007-09-12
I won’t provide an ETA at the moment. I have to fix some problems that come out with the port and then we’ll se about request. If you wish I can upload a not stable version.
 Signature
Profile
Posted: 07 September 2012 05:41 PM   [ Ignore ]   [ # 14 ]
New Member
Avatar
Joined  2008-07-19
Hey all,
While my situation hasn’t changed here, I have found a little time to play with Geppetto again (I’m experimenting with using DzControllers to non-destructively add small amounts of randomness to parameter’s values to give figures more natural motions and to simulate handheld cameras, earthquakes, etc..) I have nothing to release now and probably won’t in the foreseeable future, but I thought I’d post here about the problems that prevent Geppetto from working in DS4.X.
Geppetto is designed to work at the parameter level. It allows you to load individual parameters to be edited. Internally, the way Geppetto does this is to listen for the selectionStateChanged() signal in each parameter in the currently selected node. Each time the user selects a different node Geppetto gathers up all of the node’s parameters and connects to their selectionStateChanged() signal. The user must then click on the parameter’s name in the Parameters tab, causing that parameter to be selected and thus triggering it’s selectionStateChanged() signal. And this is reciprocal; once a parameter has been loaded into Geppetto it can be selected from Geppetto’s list or the parameters tab, which causes it to be highlighted both in Geppetto and in the parameters tab, and this gives a quick indication that you are working on the desired parameter.
The trouble with this scheme in DS4.x (the last time I checked) is that it’s version of a Parameters tab no longer allows users to “select” parameters, so there is no way for a user to tell Geppetto to load a given parameter.
Unless DS4.5 has gone back to the old behaviour of DS3 regarding being able to select parameters then Geppetto won’t work as is. The only way around this problem is to write a new parameter tab that does change the selection state of parameters (if indeed parameters still have a selection state at all!), or to mimic the Material Selection tab in Geppetto for node parameters. I rarely use the Material Selection tab that I wrote because it is so tedious to use. Unfortunately I suspect that the same will be true of a parameters tab that works the same way, but that may be the only workaround.
Anyway, if my situation changes here I may get back into developing Geppetto (only for DS3), but at this point I just don’t have the time.
Regards,
Artemia
Profile
Posted: 26 September 2012 04:19 AM   [ Ignore ]   [ # 15 ]
New Member
Avatar
Joined  2005-05-29
Any news on this?
Just found out I can’t erase key frames… WOW COME ON DAZ SERIOUSLY!?!? Why even bother putting them in. That’s like having a text editor where you can only write letters… not copy, paste, move, or erase them.
Profile
Posted: 28 September 2012 05:49 AM   [ Ignore ]   [ # 16 ]
Member
Avatar
Rank
Joined  2007-09-12
Artemia Salina - 07 September 2012 05:41 PM
Hey all,
Regards,
Artemia
Unfortunately I have not much time right now too since I am working on my thesis. I will try to experiment a bit however. Do not worry smile
 Signature
Profile
1 of 2
1
