Digital Art Zone
1 of 2
1
Caricature
Posted: 13 June 2012 01:29 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2008-01-01
At last - been trying to get this right for ages.  Retopoed in Hex a sculpt done in Sculptris - a caricature of a local politico - thanks to Johnnybevo for putting me on track grin
Image Attachments
Profile
Posted: 13 June 2012 11:21 AM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2006-02-03
Let’s really good and the topology is great!
I would get rid of that “star” on the forehead though.
Profile
Posted: 13 June 2012 12:37 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Good point - thank you red face
Profile
Posted: 13 June 2012 04:57 PM   [ Ignore ]   [ # 3 ]
Active Member
Avatar
RankRank
Joined  2010-09-22
VERY NICE and CLEAN! Now for some BUMP channeling!
Profile
Posted: 13 June 2012 04:59 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2010-09-22
I use to be terrified of making HEADs faces in HEX. Now it like everything else
Profile
Posted: 13 June 2012 08:30 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Yeah - me too.  Just couldn’t get it right, but now I’ve got the method sorted, I’m rarin’ to go make more.
Profile
Posted: 14 June 2012 01:00 AM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2006-08-23
If you ever plan to animate any of these faces you really need to rethink the topology. I just pulled this out of a quick search - http://angieanimated.blogspot.com/2011/05/character-modeling-research-ssay.html
Box modeling really doesn’t work for faces without a lot of extra work or unless they are only going to be a bust or something similar.  If you plan to use any kind of deformations, proper edge loops are essential.
Profile
Posted: 14 June 2012 04:46 AM   [ Ignore ]   [ # 7 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Thanks for the advice - here’s a screencap of him having a bit of a laugh - I didn’t make too much of an effort because the facial movement morphs will only be done properly after rigging.  Seems to deform OK.  This wasn’t box-modelled, it was done using retopology techniques, poly-by-poly.
Image Attachments
Profile
Posted: 14 June 2012 12:00 PM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
OK - I’ve taken a look at that blog - it really is modelling 101- nothing earth-shattering there.
I really don’t see how the method of constructing a mesh has any relationship to how it deforms when animated.  Whether this is done by box-modelling, point, sticking together a bunch of primitives or whatever, it is the end result which counts.  If the topology is right, with good edge-flow that follows the muscular structure, you will get good deformation when animated.
I’ve seen many methods employed by experts, and personally successfully done, many humanoid and animal figures made in a variety of methods and all either work or don’t work depending on the above criteria and the skill involved in rigging/morphing.
Profile
Posted: 14 June 2012 05:28 PM   [ Ignore ]   [ # 9 ]
Member
Rank
Joined  2006-08-23
I guess it’s just the way the ears and mouth sat that made it look box modeled? But yea, the method doesn’t matter as long as the loops work. One of the reasons I don’t do much organic modeling is because I’m horrible at getting the edge loops right.
I still think you’re going to have problems with his cheeks at least but if he’s work then all’s good.
Profile
Posted: 14 June 2012 10:33 PM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
I’ve tested all parts and it all deforms OK .
You are right, organic modelling is difficult, which is why I’ve persisted in trying to get it right.  Ears and mouth are the most difficult for me, so I’ll concentrate on those.  This is intended as a caricature, so it’s all about exaggeration.
Always battled with using reference pics, which is why I’m so happy to have managed to do this using a Sculptris model.  Sure wish that Hex had proper retopo.
Blender has really good retopo tools, but it is a pain for me to learn it.  Has anyone here used Voidworld ?  It does seem to have very good retopo capabilities, but the instructions are pretty fragmented and there is no forum that I can find.
Profile
Posted: 14 June 2012 11:13 PM   [ Ignore ]   [ # 11 ]
Member
Rank
Joined  2006-11-17
Looking good there Roygee,
Roygee - 14 June 2012 10:33 PM
Has anyone here used Voidworld ?  It does seem to have very good retopo capabilities, but the instructions are pretty fragmented…....................
Yes, what do you want to know?
By the way, the voidworld forum is here:- http://voidworld.cmcproductions.co.uk/index.php
Profile
Posted: 14 June 2012 11:36 PM   [ Ignore ]   [ # 12 ]
Member
Rank
Joined  2006-08-23
never tried doing retopology even using shrinkwrap but I generally try to keep my models lowpoly as long as I can.
Not that I’ve ever gotten one that far but in XSI I can transfer weight maps from a low poly model to a high poly one. Painting weights on high poly models is no fun so I always look at the opposite process and never used Scuptris for more than creating terrains.
I almost always use reference images tho or my proportions are way off. It takes a lot of effort to get photo reference scaled right for the different views. I tossed this together earlier and one reason it’s messed up is because I didn’t get the front and side very close. It does show were I started to go off on the topology around the jaw/cheek. That line needs to be redirected up and split the vertical line instead of making the star it is now, if that makes sense. The center strip is just a reference for me in perspective view and might or might not be deleted if I get that far.
Image Attachments
Profile
Posted: 15 June 2012 12:25 AM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Thanks Steve - and for that link - will take a look later.
The problem I have is in getting started with retopo - see the creature I created in Sculptris - it appears that the facets I started are on the surface, but they are inside the beastie.  When I zoom in any more than it is now, the facets vanish.  So the first question is how to get the facets snapping to the surface - it is in retopo mode and retopo is enabled.
It’s possible that the beastie is not selected - (does it need to be?) it is in selection mode and I’ve done LMB and MMB, but it doesn’t show as being selected.
@ admkirk - what works for me is to start the mouth and around the eye, from there down the nose and join up.  For the cheekbones I extrude and shape one strip of facet at a time along the contour of the cheeks, all the way down to the jaw, then extrude and shape to join up.
Profile
Posted: 15 June 2012 01:39 AM   [ Ignore ]   [ # 14 ]
Member
Rank
Joined  2006-11-17
Hi Roygee,
You need to reference the object first.
Load your object and select it.  On the far right hand side you will see 3 tabs(they are placed vertical next to the “Visual tools”), move your mouse over the “Scene Explorer”, a window will pop out. At the top of the scene explorer, select the “Retopo Reference List” Click on “Add from scene selection”, your object should then appear in the list. At the top of that same window is a check box “Retopo mode Enabled”, check(tick) the box to enable.
You can then go into edge mode and select the retopo tool. Click on your mesh and the vertex will snap to surface, just draw out your new polygons. If you draw 2 separate polygons, you can join/bridge them by pressing down (and holding down) the shift key, click on one edge, then click on another edge and they will bridge (the number of polygons that form the bridge is determined by the option in the right hand properties window “segments” If you want to add a new polygon to an existing polygon, press ctrl(hold down) and click an edge, release the control key and a new edge will be pulled from the edge you selected.(right click to exit)
Hope that gets you started.
Profile
Posted: 15 June 2012 09:34 PM   [ Ignore ]   [ # 15 ]
Member
Rank
Joined  2006-08-23
Roygee - 15 June 2012 12:25 AM
Yep that’s generally what I do too, eye first then that mouth. The cheek and nose really give me problems tho and that’s where I have problems getting the edge loops I want without having crazy geometry. I’m sure if I attempt it more I’ll eventually work out process.
Even tho I’m never likely to go that way I’m looking forward to hear how your retopo work goes.
Profile
1 of 2
1
