matAnim - animate material UVs, Colors, Strengths, Displacements, Bumps
mCasualmCasual Posts: 3,794
edited April 2013 in Freebies
---------; download & manual ------ https://sites.google.com/site/mcasualsdazscripts/matanim
an old script which worked well as long as you dealt with single-material objects
but yesterday i was trying to animate what you see below, and i realized there was a bug in matAnim
other things you can do with it are shown on the script's web page
512 x 512 - 254K
512 x 512 - 300K
640 x 480 - 657K
Post edited by mCasual on
  • ImagoImago Posts: 1,539
    Sorry about digging up this old post, but I wanted to ask you something about the script.
    There are a way to make it "permanent"?
    I mean, everytime I need to animate a material I load the script, adjust the options and everything goes good.
    But I need to do it everytime I open the scene!
    I work on animations and often I use the same "stage" to save up some time... If the mat's animations is saved along the others it will be very good!
  • mCasualmCasual Posts: 3,794
    edited September 2014
    was a duplicate post
    240 x 153 - 189K
    oh i didn’t know about that one
    i’ll test it right now, in DS 4.6
    yesterday/today i posted an update for mcjJet it also uses material animation
    if you didn’t see it,——> http://www.daz3d.com/forums/discussion/21263/P45/#673336
    since i needed to give a friend a particle effect built with mcjJet
    i wrote but did not publish a tool to save animated materials as a daz script
    so, very soon ( like today ) i may post that tool in this forum
    maybe i’ll make a separate version for matAnim’s animations
    fig 1 - animating the texture tiling vertical offset between 0 and 1 over 12 frames, linear interpolation -- the vertical texture tiling size is 1/12 or 0.86666667
    fig 2 - the film strip built using virtualDub and imageMagic
    virtualdub to extract the 12 images in the original nyan cat gif
    and this batch file to assemble a film strip
    c:\imagemagick\montage Nyan*.jpg -geometry 200x200+0+0  -tile 1x12 nyanstrip.jpg
    oh, indeed the animation is lost on exit !
    i'm almost certain this didn't happen for Daz Studio 1, 2, 3
    thinking ....
    800 x 800 - 179K
    100 x 1200 - 52K
    400 x 400 - 700K
    ..... mat's animations is saved along the others it will be very good!
    when its ready i will post the script here : http://www.daz3d.com/forums/discussion/46023/
    a script to save the MatAnim and mcjJet material animations as Daz Scripts ( similar to pose presets )
    Oh, thanks very much! :cheese:
    McjJet is't a life-saver too! The new options seem to be exactly what I need!
    hope it works well :)
    https://sites.google.com/site/mcasualsdazscripts4/mcjanimatsave
    lets say it's vaguely in Beta testing
    It works way better than I expected! Thank very much!
    Great work as always! ;-)
  • peter.eisenmannpeter.eisenmann Posts: 5
    edited February 2015
    - i decided to send Casual a private message instead of posting here. Sorry for the inconvencience.
    Post edited by peter.eisenmann on
  • MythmakerMythmaker Posts: 606
    It works!!! Yayyy!!!
    I didn't know this script exists so after making some MatAnim anims I spent hours/days trying to save a material animation preset to no avail.
    Just to find the solution existed all along! Hahahahahahah
    laugh
    Thanks sososososo muchhhh mCasual!
    edited July 2016
    someday maybe i'll make a script that adds properties ( ex: diffuse color )  to the node ... not the material ... but link it to the material's diffuse color property
    if i'm lucky, the animated node property will be saved along with the scene, the link to the diffuse color property of the material as well
    the idea of using matAnim to do animated spirals came after seeing the spirals by http://konczakowski.tumblr.com/
    laugh
  • DanaTADanaTA Posts: 10,098
    laugh
    Made me think of the 60's TV show Time Tunnel!   laugh
    Dana
    edited July 2016
    I almost got hypnotized by this spiral twirling and then almost forgotten what I came here to say!! cool
    After your scripts showing the potentials of mat anim, and the concepts and exciting possibilities beginning to sink in...
    Like, it would be awesome ...if we could use Puppeteer to control material animation! Like, put a dot to pose a few things, say emissive + color + whatnot then make them "blink" or "jolt like stupid" with organic mouse movement, could be fun?
    laugh
    It's also frustrating to not see matanim's material keys sync-manifest on the Timeline. I just got more indepth with Keymate, so am fantasizing if possible to jack a MatAnim track into the "V" for Values of its TRSV mode. Better still Graphmate so we can play with the curve and dynamic interpolations. Technically is it even possible? IF so I go put in a ticket...
    Post edited by Mythmaker on
