Digital Art Zone
Importing OBJ file…
Posted: 12 June 2012 12:47 PM   [ Ignore ]
Member
Rank
Joined  2003-11-09
when i attempt to import an OBJ file, it does just fine except that the groups are no longer there….. i check the box that says “read groups” but all i have is one big figure….
tia
 Signature
Profile
Posted: 12 June 2012 02:01 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
That’s right - the OBJ is not a figure, it’s just a static prop. If you want to use it as a figure you need to bring it into the Figure Setup pane and give it a hierarchy based on its groups, or you need to export and import each group as a separate OBJ file, which ever is easier.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 12 June 2012 02:33 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2003-11-09
so how do i give it a hierarchy when it’s not recognizing the groups??
 Signature
Profile
Posted: 12 June 2012 03:05 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
As I said, you use the Figure Setup pane - right-click in the Geometry panel, import your OBJ. Choose the type of rigging you want at the top. Drag the OBJ from the Geometry panel to the Hierarchy panel. Drag and drop the bones to arrange them as desired. Right-click to change rotation order, welding (if needed). Click Create. Now use the Joint Editor tool, and the polygon selection adn weight painting tools for tri Ax figures, to set the rigging up.
http://docs.daz3d.com/doku.php/public/software/dazstudio/4/userguide/creating_content/start
 Signature
Profile
Posted: 12 June 2012 03:31 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2003-11-09
ok.. that got me started….
Thanks Richard!
 Signature
Profile
