Digital Art Zone
1 of 2
1
Cannnot see through windows of object
Posted: 12 June 2012 12:42 PM   [ Ignore ]
Member
Rank
Joined  2012-01-07
I created a set using Sweet Home 3D. My goal was to create an office wall with windows, through which the audience could see buildings in a city. I created the walls, and added the windows, then exported the set as an OBJ.
I imported the OBJ into Daz Studio 4. Everything looked fine. The windows are transparent.
I wanted a large backdrop, and the backdrop function of Studio 4 would not allow me to create a panoramic view of a city with a wide jpeg image. So I created a plane and used the jpeg image as its diffuse texture.
The plane looks good. I placed it just outside the windows of the office set. I can see it just fine through the windows of the office.
Here is the problem: When I render, the background turns opaque grey. Nothing can be seen.
Any ideas?
Files attached.
Edited to remove over-sized images http://www.daz3d.com/forums/viewannounce/510_98/
Profile
Posted: 12 June 2012 01:00 PM   [ Ignore ]   [ # 1 ]
Member
Avatar
Rank
Joined  0
Possibly no light on the backdrop, turn up Ambient on the backdrop surface and see what happens. Also check that you use the 3Delight render engine, under Show Advanced Settings in the render tab. Some graphic cards mess up shadows in hardware assisted renders.
Oh.. and no picks wider that 800pixel.
Profile
Posted: 12 June 2012 01:55 PM   [ Ignore ]   [ # 2 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Could you post a wireframe view of the model - it’s possible you have polygons with more than 4 vertices around the window and those are causing render errrors.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 12 June 2012 03:02 PM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Many “modeling” packages simulate thickness with 2 polygons spaced apart.  For Glass like objects you will need to delete one of the polygons that make up the window glass.
This can be done in DS4 using the Polygon Group Editor Tool.  Select the “Extra” polygon and select “Hide Selected”  NOTE:  This setting WILL NOT save.  Therefore, you will have to re-hide the extra Polygon each time the project is loaded.
EDIT:  I’ve attached a model with the problem.  I’ve deleted part of the 2nd pane from the front window so that you can see the effect.  The side window is using the same glass shader as the front window.  Where there are 2 panes, the window is opaque.
Kendall
Image Attachments
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 12 June 2012 10:12 PM   [ Ignore ]   [ # 4 ]
Member
Avatar
Rank
Joined  0
Kendall Sears - 12 June 2012 03:02 PM
Kendall
I have used models with double planes for windows and did not have this problem. it gave a more realistic glass.
With what render/surface settings will this occur?
Cheers! Oom
Profile
Posted: 12 June 2012 11:27 PM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2012-01-07
Here are the resized (below 800 pixels) and reposted photos:
One is of the perspective view, showing the clear scene.
One is called Background invisible.png, showing the occlusion.
I inserted a light between the building and the cityscape, and you can see the cityscape better in this render, filename Background visible.png. Nevertheless, you can still barely see out of the windows.
For the windows, I used a Sketchup figure that I exported to DAE format for import into Sweet Home. The Google Sketchup warehouse filename is ICA3755 3W.skp. I am unable to attach this kind of file to a post in this forum.
Image Attachments
Profile
Posted: 13 June 2012 07:14 AM   [ Ignore ]   [ # 6 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
What are the surface settings for your glass material?  Also what are your advanced render settings?  Specifically Raytrace Depth?
 Signature
My Tutorials and Freebies Index
Profile
Posted: 13 June 2012 07:34 AM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Oom Fooyat - 12 June 2012 10:12 PM
Kendall
Cheers! Oom
I guess I should qualify my statement…  “At the default render settings…”  I should have been more clear.  I made an assumption of the use of the default settings when I made my statements.
Kendall
 Signature
Profile
Posted: 13 June 2012 08:24 AM   [ Ignore ]   [ # 8 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
adamr001 - 13 June 2012 07:14 AM
Yes I would be looking at Raytrace Depth as well. Looks like the light isn’t getting all the way through the windows hence the grey.
 Signature
Pete
Community Volunteer:
If by some miracle I express an opinion then it is my own and not that of Digital Art Zone.
Somethings to Consider when starting to learn CG
My Render Thread
Proud member of the Bald Wizards Club
Profile
Posted: 13 June 2012 08:29 AM   [ Ignore ]   [ # 9 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
Szark - 13 June 2012 08:24 AM
Could also be specular values including multiply through opacity being off, diffuse strength, ambient values, etc.  Lots of things going into making glass look like glass, but I’m definitely thinking Raytrace Depth… ^_^
 Signature
Profile
Posted: 13 June 2012 08:43 AM   [ Ignore ]   [ # 10 ]
Addict
Avatar
RankRankRankRank
Joined  2009-05-14
adamr001 - 13 June 2012 08:29 AM
Agreed but from my expereince most of the time it is due to not having a high enough raytrace depth. But yes all those above should be chcked anyway.
 Signature
Pete
My Render Thread
Profile
Posted: 13 June 2012 01:04 PM   [ Ignore ]   [ # 11 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Ray trace depth shouldn’t affect surfaces that aren’t set to reflect or refract, surely?
 Signature
Profile
Posted: 13 June 2012 01:29 PM   [ Ignore ]   [ # 12 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
Richard Haseltine - 13 June 2012 01:04 PM
Raytrace Depth affects the ability of light to penetrate transparent items.  You need [Layers of Transparency] + 1 as your raytrace depth for those items to pass light and cast a shadow.  Just like you need [Number of Reflections] * 2 = Raytrace depth to do reflections of reflections style renders.
 Signature
Profile
Posted: 13 June 2012 01:53 PM   [ Ignore ]   [ # 13 ]
Member
Rank
Joined  2012-01-07
Regarding the properties of the glass, the set is all one piece, so I had to use properties for the glass that I use for the rest of the wall.
Regarding “raytrace depth,” how do I adjust that?
Profile
Posted: 13 June 2012 01:56 PM   [ Ignore ]   [ # 14 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
PhoneyBaloney - 13 June 2012 01:53 PM
In DS4 you can use the Polygon Group Editor to select polys and assign them to your own shading groups.  So you could assign the window glass to a group called “glass” and then use a glass shader on that group.
The raytrace depth is in the Render Settings tab.
Kendall
 Signature
Profile
Posted: 13 June 2012 02:30 PM   [ Ignore ]   [ # 15 ]
Administrator
Avatar
RankRankRank
Joined  2006-03-14
Eh, I just did some testing because of what Richard said and he’s right.  It looks like somewhere since the last time I tested this (back in DS2 or even DS1.8 days) things have changed.
I created four planes, a ground plane, and three others.  The three others were raised on the Y-axis and each given their own transmap (the numbers 1, 2 and 3 in pure white, the rest pure black).  Specular strength and ambient strength were set to zero.  A distant light was added and rotated -90 on X-axis and raytraced shadows set.  Raytrace depth was left at 2.
Works fine. (see attached)
Makes me think my other possibilities earlier were correct.  Specular and/or Ambient settings.
Image Attachments
 Signature
Profile
1 of 2
1
