3DAGE - 23 March 2013 10:30 AM
HI Sue25
I hear your frustration,. and sympathise,..
You shouldn’t need to uninstall the Trial/Demo,. (it;‘s the same program a the FULL PRO version of Carrara,. and your serial number unlocks it.
If you’ve run to the end of the 30 day trial,. then it should still allow you to “Register Carrara” by adding your serial number, by clicking n the Daz Logo (see pic)
Your name will be there,. all you need to do is add your Carrara 8 serial number4 from your store Account, and the program will change from Trial/demo,.. to Carrara 8, Standard or Pro, based on your serial number.
You need to be running the program as “Administrator” to allow the serial number to be retained,
To do that,.. you right click on the Carrara shortcut, and select “run as Administrator” from the menu options.
If Win7’s UAC (user account control) causes any problems in doing that,. simply disable it in the Control panel / user accounts / change user account control settings.
Serial numbers are added to your programs to ensure that you have a legitimate copy of the product. as well as deterring software piracy. that’s a practice which applies to most commercial software,. it’s not something new to Daz3D.
If you want to remove Carrara completely from your system,.
First,.. uninstall the main Carrara application, and the native content installers
next,. remove the Preferences file (created after installation by the user) by going to…
Users \ Your name \ Appdata \ Roaming \ Daz3D \ Carrara 8
and remove the preferences file.
While there’s still some registration info “that you’ve Run the Trial version” saved within your machine,. this shouldn’t prevent you from installing a Full version of Carrara, and registering it.
It will stop you from re installing the trail version to get another 30 days of using carrara for free.
that’s what it’s designed to do.
Hope it helps :)
I just un-installed the program, and tried to navigate to the path you suggested “(Users \ Your name \ Appdata \ Roaming \ Daz3D \ Carrara 8)”.
This path does not exist on my system, what i do see related to C8 is…................... Users/my name/My Documents/DAZ 3D / Carrara 8.5/My presets. In the preset folders there are 7 folders:
My Artwork
My Clips
My Constraints
My Effects
My Modifiers
My Objects
My Shaders
Also what I should point out is ...while i did several installs and un-installations ...at no time during the installations did I changed the default file path selected by C8 for installation.
I kept good records..I had the serial number backed up in my personal files prior to this conversion. In addition I went back to DAZ website and double check the number. I copied and paste, hand-typed in the number several times ....nothing works!!
I tried run as administrator…I uninstalled and right click on the installation file and selected run as administrator, I tried opening the file as an administrator. I check the settings in Win-7 and I am the only user and the administrator
Even if I’m using the file as trial, I see where at any point you can go to the registration link, did that many times and it does not work. Personally, I think its unacceptable to start using the program in trial mode. Something is wrong, and I need to fix it.
