Digital Art Zone
1 of 11
1
DAZ Studio 4.5 Release Candidate 2
Posted: 11 June 2012 10:35 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2007-10-08
DAZ Studio 4.5 RC2 is available for download!
This build is available to all customers and will run either without a serial number (you will be asked to enter one each time you launch the application until you do), or with your current DAZ Studio 4.x serial number.  Installing DAZ Studio 4.5 RC2 will uninstall any previous installations of DAZ Studio 4.x, and we recommend running only one version of DAZ Studio 4.x on the same machine.
The purpose of this build is to provide users with early access to new features and bug fixes that are only available in DAZ Studio 4.5.  This build is a Release Candidate, which means we are looking for prompt feedback about significant issues that may still exist in this build as we approach the General Release.  To help our Quality Assurance and Software Development teams, please focus any reports you make on issues that are significant blocks, crashes or other “show-stopper” caliber issues, rather than requesting new features, user interface and/or workflow changes.
New in DAZ Studio 4.5:
1. Full implementation of the DSON file format specification - This enables saving scenes in a lightweight format that can be loaded and used by anyone who has installed the products used in the scene.  If one or more of the assets used in the scene are not found while the scene is loading, a simple preview is inserted into the scene in its place and a dialog is displayed indicating which files are needed to load the scene in its entirety.
2. Selectively save parts of a scene - Save only those items in the scene that you choose, rather than having to remove items from the scene before saving.  Then, easily drop that scene subset into another scene using lightweight DSON format files.
3. Viewport speed dramatically increased - For many interactions, viewport speed will be 2-5 times faster than DAZ Studio 4.0.
4. Load and use most Poser format files as if they were native DSON files - Scenes that are constructed using items loaded from Poser format files and then saved to the DSON format, are also sharable; they maintain references to the required Poser files, rather than the contents of those files.
5. Consolidated viewing/editing of Property Settings - The Property Settings dialog now consolidates more editable information about each property into a single interface; e.g. Presentation Editor, Controllers, Sub-Components, Keys, etc.
6. FBX Import - FBX files can now be round-tripped through DAZ Studio, including rigged and animated items in the scene.
7. “Darkside” style is now included - You no longer need to download and install this style separately, it is included as part of the standard installation.
8. Relaxed serial number requirements - No serial number is required to run either the 32-bit or 64-bit versions of DAZ Studio Standard Edition.
9. Shader Mixer improvements - Shader Mixer has significantly improved workflow and documentation.
10. New “Ready to Render” scenes - New scenes that are “Ready to Render” have been added as part of the content that installs with 4.5.  Loading these is a great way to start tweaking and playing with some cool scenes.
11. Lesson Strip - We’ve added quick lessons about DAZ Studio basics.  There are also instructions on how to create your own Lessons on the Documentation Center.
Along with many new things in DAZ Studio 4.5, you will also find new documentation on some of the deeper functionality in DAZ Studio on the Documentation Center in the Publishing and DAZ Studio sections.
If you find any serious issues please report them with as much detail as you can in the DAZ Issue Tracker.
What you need to know about this build:
1. Many, many issues and workflow improvements have been addressed since we released 4.0.3.47. Too many to list here. Please see the DAZ Studio 4.5 Change Log and the DAZ Issue Tracker for more detail.
2. Files saved from this version of DAZ Studio are NOT backward compatible with older versions, including version 4.0.x.
3. Plugins that run in version 4.0.x will not run in version 4.5.
4. When installing the plugins that come with DAZ Studio, you may see warning dialogs indicating there was a problem with installation. These warnings do not affect installation, but we are addressing the warnings in a later build.
5. Not all features of FBX are supported on import, so characters from other 3D applications imported in FBX format may or may not come through with all their components.
6. All presets are saved in lightweight DUF format and scripted presets (DSA files) have been deprecated. DSA presets will still save and load, but the new preset format should be used in their place.
7. While the deprecated .daz scene format can still be read, the option to save to the format has been removed; too many crashes were being caused by the use of an area of the application that has been deprecated and will not be developed further.
Thank you for helping us make DAZ Studio great!
You can get this version here:
DAZ Studio 4.5 RC2
Profile
Posted: 11 June 2012 11:09 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
Fantastic!
Kendall
 Signature
Any opinions expressed in this post are those of Kendall Sears and may, or may not, be more, or less, valid than any other opinion.
The contents of this post are intended for the DAZ forum only, do not re-post any portion to any other forum without his permission.
Profile
Posted: 11 June 2012 11:15 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2005-10-21
I haven’t had any significant probs with RC1, so I’m looking forward to using this update.  Speed increases are very welcome and make the whole scene set-up process much more enjoyable. smile
 Signature
May I be excused? My brain is full….... tongue wink
My Renderosity store
My dA Gallery
Profile
Posted: 11 June 2012 11:52 AM   [ Ignore ]   [ # 3 ]
Moderator
Avatar
RankRank
Joined  2007-10-17
Just a quick clarification on this. You can run both 32 bit and 64 bit on the same machine and one will not uninstall the other. Given that, I will also note it is not recommended to have two different versions of DAZ Studio, for example 4.0.3.47 and 4.5.0.49 on the same machine, even if one is 32 bit and the other is 64 bit.
DAZ_bfurner - 11 June 2012 10:35 AM
Profile
Posted: 11 June 2012 12:23 PM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  0
Cool! I just tried to get it, it’s listed as “pending” and I can’t reset the download, though.
Probably a minor glitch.  As soon as it shows up, i’ll give it a spin.
 Signature
My bloggity blog: http://the-serpents-fang.blogspot.com/
My DeviantArt site: http://theserpentsfeather.deviantart.com/
My red Room Authors Page: http://redroom.com/member/edward-averill
Profile
Posted: 11 June 2012 12:25 PM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
It’s almost completed downloading here.  I’ll fire it up and let everyone know.
Kendall
 Signature
Profile
Posted: 11 June 2012 12:37 PM   [ Ignore ]   [ # 6 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
DAZ_Spooky - 11 June 2012 11:52 AM
DAZ_Spooky,
  Since you’re here can you give a quick answer on an interesting entry in the changelog?
From the Changelog:
“Added method to content manager to open a list of files; after each file is loaded a process events is called, allowing routines such as AutoFit to process on the recently loaded item and preventing a lockup condition from occurring”
Can these events be tied into by content themselves or via a plugin patch?
Kendall
 Signature
Profile
Posted: 11 June 2012 12:45 PM   [ Ignore ]   [ # 7 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
The file has downloaded and the extra corruption is appended.  So those of you with finicky zip programs will need my utility.
Now on to playing!!
Kendall
 Signature
Profile
Posted: 11 June 2012 12:58 PM   [ Ignore ]   [ # 8 ]
Moderator
Avatar
RankRank
Joined  2007-10-17
Kendall Sears - 11 June 2012 12:37 PM
DAZ_Spooky,
From the Changelog:
Kendall
For Example, load a base figure, like Genesis. Multi-select a handful of clothing items in either the Smart Content Tab or the Content Library Tab, then drag and drop onto your base figure. All the clothing will apply to the Base figure. If appropriate, auto-fit will also work for one or more of the selected clothing items.
Profile
Posted: 11 June 2012 01:03 PM   [ Ignore ]   [ # 9 ]
Power Member
Avatar
RankRankRank
Joined  2006-02-17
DAZ_Spooky - 11 June 2012 12:58 PM
DAZ_Spooky,
From the Changelog:
Kendall
Right.  I want to know if I can write code that adds functionality into this system.  For instance, truly “smart” content.  Content that can adapt to its environment.
Thanks
Kendall
 Signature
Profile
Posted: 11 June 2012 01:09 PM   [ Ignore ]   [ # 10 ]
New Member
Joined  2005-11-15
Just so you know, this version of studio 4.5 is no more compatible with the abominable Windows 8 than the previous one, so the content uninstaller and the new content installer simply do not work. I’m still stuck with the old content, but it’s not a huge problem, just an annoying one.
Edit: On the plus side, I was able to get a .duf scene file size down from 67 megs to 384 kbs, so that’s definitely a good thing. Of course, I can’t be entirely sure it’s because of this version or not.
Profile
Posted: 11 June 2012 01:27 PM   [ Ignore ]   [ # 11 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
One thing I will say.  Last night, using the first RC I tried to save a .duf file using the Selectively save option to only save the vest that I modeled and rigged and when I tried to load it up again it crashed DS 4.5 so hopefully this is fixed??  Thanks for the update!!  cool grin
 Signature
—-Wolff On The Prowl—-
Posts: 28,985 and counting!
        RAMWolffsWorld
Profile
Posted: 11 June 2012 01:37 PM   [ Ignore ]   [ # 12 ]
Moderator
Avatar
RankRank
Joined  2007-10-17
jwood331 - 11 June 2012 01:09 PM
We are working on the Windows 8 issue with the Content Installer. Thanks for pointing it out, but it is one we knew about. smile
Profile
Posted: 11 June 2012 01:40 PM   [ Ignore ]   [ # 13 ]
Moderator
Avatar
RankRank
Joined  2007-10-17
Kendall Sears - 11 June 2012 01:03 PM
Thanks
Kendall
I am not sure, exactly, what you are looking for but you may wish to check out hte new Wearable preset for DUF files. smile Whole outfits with one preset. smile From what I understand it even already goes farther than that. for example a flight suit for a pilot who is in turn connected to an aircraft.
If that is what you are looking for, no need to code as it is part of the plan. smile
Profile
Posted: 11 June 2012 01:52 PM   [ Ignore ]   [ # 14 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
I suspect Kendall may want to trigger a script on load, to (for example) change the morphs or textures if the male or female morph is set on Genesis. Actually, I thought there was already meant to be an event-triggered script option, though when it was last discussed (possibly back in DS3 days) it wasn’t working and Rob needed to work on it.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 11 June 2012 02:13 PM   [ Ignore ]   [ # 15 ]
Addict
Avatar
RankRankRankRank
Joined  2004-08-11
Wish someone could write a script that could be run to fix all the meta data automatically if things were moved around a bit.  I like my male and female stuff put into separate folders so that’s really about all the moving around that I do but I do do that.  Also some merchants don’t use the “Materials” folder option and will put the MAT files elsewhere so I hunt those down and rename the folder Materials and put that in the appropriate clothing or hair folder!
 Signature
        RAMWolffsWorld
Profile
1 of 11
1
