wao,,
“genesis” with man face come in, when you click “genesis dsf” in smartcontents ?! ><;
I think there are two possibility.
1. when you load genesis.dsf , generation x apply morphs with your genesis figure automatically.
Can not you find the shape morph parameter “the mans face”?
I think there seems to be option of generation x, when you load genesis, apply the morph automatically,,
2 1. as you say, the genesis.dsf was overwrriten. .but you uninstall contents,,,
(if you reinstall so many times, sometimes uninstaller can not clean up your contents,,)
you may check where is your genesis.dsf .(which references to)
On smart contents , right click>Show in content library.
Content library pane may open.
Now you can find Genesis.dsf in content library
On content library, right click “Genesis.dsf ” >Browse to file location.
this is your genesis.dsf.
It should be \(your daz contents folda\)People\Genesis\genesis.dsf
(I hope you do not have many genesis.dsf,,, in your HD)
then, you can check the time when “the genesis.dsf is updated”. in windows exproler.
if the “updated time” is after you transfer morphs by generation X,
it seems to be overwritten.
and you can uninstall generation X, can not U?
Now IMO it is best way to clean your genesis.
(after uninstall, you can reinstall generation X from your account. (you need not pay again )
I hope someone who use the generation X , and they can help you. ><;
(if you want to try ds 4.5 RC, in 4.5RC, you can not use generation X,
and it overwritte the refferetnce of ” genesis dsf” to “genesis duf.”
so you can load “original genesis “
but,,, I do not think it is best way,,
