(Thanks jederlail, I did not think about this case ):shut: edited again.
case 1
If you want to just check your render image on render library,
set Folder: value to “render”, (click right small arrow ) top of “Render library pane”,
when you render the seane.
you can see the image on Render library without saving the image.
case 2
if you want to save your render image at “default directory of Render Library “, and check it in render library,
set Folder: value to “Render library”, (click right small arrow ) top of “Render library pane”,
after you render seane, (check my image)
a) you should set your image Name and format(jpg, etc).
b) set Library , and ” Render library” by small arrow. bottom of “render view”
c) do not forget “save” it!
(case 3)
if you want to set new folda in Render library to save and check your image,
(Render library easy setting tutolial) (is it need for someone? )
1. Make “library folda” for your Rendered image (anywhere you want to).
eg F:\yourname\image\dazalbum
(If you have had your library directory, you do not need to make new folda)
2. click “Render tab” on Activity bar (under top menu)
3. click “Render library tab” , Render library show .
4. there is no image? do not mind. you can set path of “library folda”
5 Now call “render directory manager”. L click, top right corner small square (edited)
then choose “render directory manager”
6 Now you can see, tree of directories.
Look, Current Directories > “Base Paths”
click small triangle left of “Base Paths”
you may see some ” Base Paths” (image 1)
left click ” Base Path”. Now I want to add “library folda” (which you made (1.))
to “Base Path”
check, Yellow square line must coverd “Base path”. It should not be
“I:\ e\dazstudio4\ or some true pathes”
If you click “Base Path” ,“add” button (left side of the pane”) may turn clear black.
7. Now you can “add” your “library folda” to “Base path”. just click “add” botton.
8. Folda exproler (“Select a Directory”) may show up, choose your “library folda”.
then “select folda” ( MY PC is for jpn, so I do not know what name for “OK” button) click.
9 Now you can see your “library folda” is setted in ” Base path"s. click “accept”.
10 Once you set your “base path” s, ( “library folda”) you can access and change your
base folda in Render library pane. or Render image viewer.
11 On Render Library pane, top area , you can see Folda : “value button” with
“small arrow”.
click “small arrow” and choose your “library folda”
(of course you can make another category , in your library folda, but now simply select your “library folda” which you made before)
12 Let’s test render ! see image 2
a) you should set your Name and format(jpg, etc).
b) set Library , and your” Library Folda” by small arrow.
Happy Birthday?!
