Digital Art Zone
90 of 101
90
Star Trek Builders Thread!
Posted: 12 October 2012 09:52 PM   [ Ignore ]   [ # 1336 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-16
PDSmith - 12 October 2012 09:45 PM
TheCastellan - 12 October 2012 08:31 PM
All I want is the item I load up to look just like in the preview image as seen on page when one downloads said items.  Like that Voyager bridge looked all nice with the Okadagrams and everything.  Seems like Daz is pretty much a red headed stepchild or something.  And I do want to get my comic going as quickly as possible, I promised myself that by 2013, the comic will be up and going.  There’s these texture folders in some of these files, like the Hornet bridge, but I got to figure out how to make them appear.  Hopefully I can get that working with some of the steps offered here.
Trying….
in the surface tab as I pointed out IF there is a file name in the Diffuse section. click on the name, then click browse. DAZ will take you to the directory where the files are. Rduda often provides two textures for his sets.  match the alternate texture if you are looking for another look.
As for trying to look like the adverts and promo images. Most of the sets you will find are geared toward poser and/or have poser based light settings.
Poser’s Firefly renderer is better than DAZ’s 3delight but Poser lacks the stability I look for in my images.  Each system has pros and cons.  DAZ from most people I’ve talked with is easier to learn for someone with zero 3D experience…and then when you go to Poser it’s easy to learn also..but from what I’ve seen a Poser user has problems learning DAZ…just one of those things….Ask ShadowHawkOne…he’ll testify on that issue.
So back to the problems at hand, With a bit of fiddleing, you’ll note if you take the light percentage down to 25% or so things will work out.
In my case I prefer to start from scratch and use the lights from the ‘firey Genesis’ set (part of 4.5) .I know you are using DAZ 3 but seriously consider useing DAZ 4.5 I was hesitant but now find it the best, fastes and most stable.  3 is pathetic in my eye’s. but if you wish to stick with it for now. no problem, I’ll do what I can.
Start simple for your comic.  Here is my first one. http://pdsmith.deviantart.com/gallery/35287680#/d3f5xe1  is looks like hell in the beginning but as I went along things got better…in my opinion.
Lights are a task in themselves..I’ll write something up to help in a bit.
I’m going to jump in here a second with my 2 cents worth. Before you start the artwork for your comic, make sure you have everything laid out and planned in advance- you’ll head off alot of problems that way.  This is one reason that each of my Nova Treks takes so long. I make sure I have everything figured out before I start the artwork. Pays off in the long run.
Profile
Posted: 12 October 2012 10:00 PM   [ Ignore ]   [ # 1337 ]
Active Member
Avatar
RankRank
Joined  2009-07-12
mdbruffy - 12 October 2012 09:52 PM
I’m going to second that point….in almost all cases I’ve set up the set before adding people…tinkering with lighting before hand is so much easier!
V4/M4, M3/V3 and Genesis slow things down and with hair it’s gets worse especially if you use Image based lights (uber stuff..)
 Signature
Don’t resist change! Subvert from within!
Profile
Posted: 12 October 2012 10:05 PM   [ Ignore ]   [ # 1338 ]
Active Member
Avatar
RankRank
Joined  2011-04-14
Here’s some visual aids that might help explain myself:
Here’s the voyager bridge I mentioned:
http://www.sawvision.com/freebie-rdbridge1.html  As you see, it looks all nice and pretty and I went, “Say, that looks pretty darned good, I’ll get that!”  So I download it and unzip it into content, and I open it up and this is what I get:
1: Shiny, featureless, useless plastic like bridge T_T
2: And I look in the zip folder and I see this:
The textures and skin or whatever one calls them are there, I just don’t know how to get to them. @_@
3: And here’s another zipfile of that TOS bridge, the older style, one:
4: And here’s the textures/skins for it.:
If I could figure out this dilemma, everything shall be fine, then.
And when I go and buy some of those bridge sets like Vanishing Point has, I hope it won’t be a nightmare like this has been so far. >_<;
Image Attachments
Profile
Posted: 12 October 2012 10:17 PM   [ Ignore ]   [ # 1339 ]
Active Member
Avatar
RankRank
Joined  2009-07-12
I know the problem…I had the same thing….back in a bit with the solution!
I need to load the set and look at the setting under the surface tab.
-Paul
 Signature
Profile
Posted: 12 October 2012 10:32 PM   [ Ignore ]   [ # 1340 ]
Active Member
Avatar
RankRank
Joined  2011-04-14
PDSmith - 12 October 2012 10:17 PM
-Paul
I MIGHT have solved the thing regarding the monitors, in the very least.
Well, it’s a small step, but a step none the less.
Profile
Posted: 12 October 2012 10:35 PM   [ Ignore ]   [ # 1341 ]
Active Member
Avatar
RankRank
Joined  2009-07-12
Okay easy fix…when you load the bridge file…it will ask you for the textures…you need to scroll back to the RD BRidge 01 Texture. The first file it will ask you for is HELM101 or something like that…scroll WAY down the list to the file…DAZ will keep to the directory and load the rest of the textures automatically
lights…they need to be toned down.
http://www.sharecg.com/v/47446/gallery/21/DAZ-Studio/Four-Lights-for-Daz-Studio-3
http://www.sharecg.com/v/61695/browse/21/DAZ-Studio/UberEnvironment2-Light-set5-(for-SkyDome-Exp5)
http://www.sharecg.com/v/61739/browse/21/DAZ-Studio/UberEnvironmen2—-mixed-set-1
the above three will task the hell out of your computer the quality if fantastic.
http://www.sharecg.com/v/33904/browse/21/DAZ-Studio/Dyalds-EZ-Lights-2
those lights were my first lights I used for my first comic.  just remember to delete the leaf object file.
 Signature
Profile
Posted: 13 October 2012 08:37 AM   [ Ignore ]   [ # 1342 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-16
Anyone remember this guy? He’s called “Flayer”. I want to use him as a background alien- crowd scene- but I have aproblem. I have the character files and the Pose files, but sometime over the years, I’ve lost the texture files. Can anyone help me out with this?
Image Attachments
Profile
Posted: 13 October 2012 09:22 AM   [ Ignore ]   [ # 1343 ]
Member
Rank
Joined  2012-02-16
mdbruffy - 13 October 2012 08:37 AM
If you have lost the textures (which should be under “textures\sixus1\flayer”) Sixus1 has released the critter as a freebie at:
http://www.sharecg.com/v/58912/View/11/Poser/Flayer
Hope this helps.
Profile
Posted: 13 October 2012 09:44 AM   [ Ignore ]   [ # 1344 ]
Power Member
Avatar
RankRankRank
Joined  2004-07-16
MenehuneMagic - 13 October 2012 09:22 AM
Hope this helps.
I looked at that and it appears to be just that robe. But it’s okay. I went digging through my storage discs and found the original zip file, so I’ve found them.
Profile
Posted: 13 October 2012 09:57 AM   [ Ignore ]   [ # 1345 ]
Member
Rank
Joined  2012-02-16
mdbruffy - 13 October 2012 09:44 AM
Hope this helps.
The file does include the flayer (and the flayer textures) along with the clothing. I just double-checked grin Should your archived file be corrupted you’ll still have access to the critter’s textures at the link above.
Profile
Posted: 13 October 2012 09:59 AM   [ Ignore ]   [ # 1346 ]
Member
Rank
Joined  2005-01-01
Well, until I hear back from someone who can help me with my MAT Poses problem, I’ve started working on something else.
I recently got the “Starship Bridge 5” from VanishingPoint. And while it really is a good model of the First Contact era bridge, it has its problems. Problem numero uno for me was that the command chairs (captain, first officer, counsellor) were too small. Tiny, in fact. What makes matters worse, the chairs are part of the base mesh, not seperate props or characters. So, I couldn’t fiddle with the scale of the chairs without effecting the scale of the base.
So, I got the free download load of Hexagon last Saturday. Imported the base. And went through the process (and steep learning curve of Hexagon!) of making the base seperate props. I wound up with the base, captain’s chair, first officer’s chair, counsellor’s chair, first officer’s console, counsellor’s console, and the helm/ops consoles. Scaled each component appropriately, and started working on making my next project: the bridge of the U.S.S. INVICTUS!
The first thing I did was change the color scheme of the bridge from brown and tans to blue and grays because I wanted a more militaristic looking ship. I added the helm console from RDUDA’s Hornet bridge to act as the main tactical console (yes, there are THREE tactical consoles on the bridge! But, it works with the type of ship the Invictus is.). I, also, changed some of the graphics.
This is still a work-in-progress, so, be kind.
Image Attachments
 Signature
“Time is a fire in which we all burn.” -Dr. Tolian Soren
Profile
Posted: 13 October 2012 10:34 AM   [ Ignore ]   [ # 1347 ]
Active Member
Avatar
RankRank
Joined  2004-12-14
blubeetle3 - 13 October 2012 09:59 AM
Looking good so far.
Be careful…..
It is REAL easy (and a lot of fun) to get distracted pulling models into Hexagon and modifying them to suit your needs.  My stories are in the TOS era & I have had a great deal of fun disassembling TOS ships and sets and rebuilding them to suit my needs.
The other distraction is pulling textures into the image program of your choice & modifying the textures.  In the long run, that will be more useful - by swapping out textures, you can turn almost anything into a Trek item.  As an example, over on Poserworld, they just released a model of the UN Council chambers - by swapping out some textures, it will become a UFP council chamber - your only limit is your imagination.
 Signature
“Facts do not cease to exist because they are ignored” - Aldous Huxley
Profile
Posted: 13 October 2012 12:05 PM   [ Ignore ]   [ # 1348 ]
Member
Rank
Joined  2005-01-01
ssgbryan - 13 October 2012 10:34 AM
Be careful…..
You’re telling me! I’ve got like a dozen different things I’m working on simultaneous! big surprise
Still looking for a ship I like to actually be the Invictus. Right now, it’s an Insignia class. But, I’m leaning more and more toward the Ascension class. Still not good enough at Hexagon to do any major modification to ships.
Right now, I’m in the set building and character building stages. If anyone’s interested, I’ll post more of my WIPs.
 Signature
Profile
Posted: 13 October 2012 12:21 PM   [ Ignore ]   [ # 1349 ]
Active Member
Avatar
RankRank
Joined  2009-01-14
To convert 3ds files to obj files with textures that daz studio can use - go download POSERAY - it is an easy program that converts to various formats from various formats
https://sites.google.com/site/poseray/
 Signature
my art: http://mototsume.deviantart.com/
or http://mototsume.webege.com/
freebies:  http://mototsume.webege.com/downloads.htm
Old Post Count: 1773
Profile
Posted: 13 October 2012 06:53 PM   [ Ignore ]   [ # 1350 ]
Active Member
Avatar
RankRank
Joined  2011-04-14
There a way, for example to put okudagrams on Ptrope’s TOS bridge?  I am trying and on the black of the panels, it stays black.
Thanks.
Profile
90 of 101
90
