Digital Art Zone
Placing texture in viewport differs form render.
Posted: 10 June 2012 02:40 PM   [ Ignore ]
New Member
Joined  2012-04-03
Hello!
I have added a picture to show you guys what I mean. I have placed these textures very carefully to get this simple trouser result. But they drop half-a-trouser-panel when rendering.
So what did I do? I can’t find a way to change it…
Thank you again!
bye,
Marjolein
Image Attachments
Profile
Posted: 11 June 2012 07:13 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
HI lijlijlijntje
I take it that this is a custom texture, you’ve created, and it’s not one that comes with the clothing product…
Did you use a template from the clothing to create the texture map ?
If yes,.. then it should fit.
if no, then the UV layout may be different.  ..and it wont map correctly.
Posting a screen capture of your shader settings, including the diffuse channel with the texture map settings may help someone to help you.
It looks like it’s Tiled / repeating.
Profile
