Digital Art Zone
1 of 3
1
17 chic clothes problem
Posted: 08 March 2013 06:47 AM   [ Ignore ]
New Member
Avatar
Joined  2003-10-09
Anyone has the same problem with 17 chic clothes ?
A hole appears on long sleeve shirt when applied on genesis character ...
Hole appears on all characters I tested (Aiko5, Stephanie5, Victoria5, Julie and default genesis character).
Using DAZ Studio Pro 4.5.1.56 (64bit)
See picture ...
Image Attachments
 Signature
Profile
Posted: 08 March 2013 07:40 AM   [ Ignore ]   [ # 1 ]
Member
Rank
Joined  2012-07-06
No problems here on default V5, Julie YT5, A5, or some GenX blends I have.
Profile
Posted: 08 March 2013 07:51 AM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2011-09-11
+1
same here, in addition there are issues with the back of this item.
In addition there are issues with the store and discounts did not apply for all the items in the category. The funny thing is I did not even want this item it was just the best choice to get the 50% discount on another item.
Just an FYI,
most people will look the other way on the store, site, checkout issuse if the products are good, once you add sub-par products to the mix the future looks grim.
back to sales support for a refund, or the better path is to just log into paypal and work from there
Profile
Posted: 08 March 2013 07:52 AM   [ Ignore ]   [ # 3 ]
New Member
Avatar
Joined  2003-10-09
3d-username - 08 March 2013 07:51 AM
+1
Yes, I just noticed holes in the back of the clothes ...
Image Attachments
 Signature
Profile
Posted: 08 March 2013 08:00 AM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2004-04-14
I did not buy this but do either of you have a smoothing modifier applied or on for that matter?
Also, in the Parameters Tab, does the item show as being fitted to Genesis or not at all?
 Signature
My DAZ3D Store
My Free Stuff
My Art @ DeviantART
Ships of the Line - MEGA THREAD
How to use the Poser Format Exporter - **Updated 2013-02-09**
Profile
Posted: 08 March 2013 08:06 AM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  0
Looking at what installed into a clean runtime, I’m only getting shirt morphs for Basic female and Reby Sky (FBMBasicFemale.dsf and FBMRebySky.dsf) in the data directory.
This was using the manually downloaded file ‘15534_17Chic_1.0_trx.exe’ - are folks using the DIM getting the proper files perhaps?
Profile
Posted: 08 March 2013 08:07 AM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2011-09-11
The issue seems to be with the base mesh.
I have to say that all this is just such a wase of time.
Profile
Posted: 08 March 2013 08:08 AM   [ Ignore ]   [ # 7 ]
New Member
Avatar
Joined  2003-10-09
Mattymanx - 08 March 2013 08:00 AM
In parameters tab, clothes are fitted to genesis character.
About smoothing all these parameters are active :
Mesh Smoothing
Enable Smoothing : On
Smoothing Type : Base Shape Matching
Smoothing Iterations : 2
Interactive Update : On
Collision Item : Genesis
Collision Iterations : 3
When the short shirt is there, no hole ...
Comparison without / with the short shirt.
Image Attachments
 Signature
Profile
Posted: 08 March 2013 08:29 AM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2011-09-11
i have a question for an admin:
while i would like to qa this product and hope others get to the source of the issue, i need to move along to other things.
i purchased this item with another item to get the 50% off, i reall wanted another item in the category sale that i could not get the discount to apply. it seems like the discount is working today on all the items i want, should daz reverse the entire order so i can re-purchase one item today or is it better to reverse just thismitem and i can purchase the 2 items i wanted?
thanks in advance
Profile
Posted: 08 March 2013 08:40 AM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2008-11-10
No issues here. Used manual installer.
Image Attachments
Profile
Posted: 08 March 2013 08:44 AM   [ Ignore ]   [ # 10 ]
Member
Rank
Joined  2011-09-11
Male-M3dia - 08 March 2013 08:40 AM
you need to change the opacity of the front shirt to 0 to see the issue,
to do this select the shirt, go into the surface tab, select the top shirt and set the opacity to 0
Profile
Posted: 08 March 2013 08:44 AM   [ Ignore ]   [ # 11 ]
New Member
Avatar
Joined  2003-10-09
Manual installer here too ...
But holes on shirt appear when you change opacity of the short shirt,
can you try to see if you have the issue without the short shirt ?
 Signature
Profile
Posted: 08 March 2013 08:51 AM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2008-11-10
3d-username - 08 March 2013 08:44 AM
Still solvable.
Increase smoothing to 7 and collision to 15. Smoothing is generally set down lower in DS 4.5 for instances like this.
Image Attachments
Profile
Posted: 08 March 2013 08:52 AM   [ Ignore ]   [ # 13 ]
New Member
Avatar
Joined  2003-10-09
Male-M3dia - 08 March 2013 08:51 AM
Still solvable.
Wow, that solved the problem !!
Thank you very much Male-M3dia !!! smile smile
Image Attachments
 Signature
Profile
Posted: 08 March 2013 09:04 AM   [ Ignore ]   [ # 14 ]
Power Member
Avatar
RankRankRank
Joined  2004-04-14
edit:
nm
 Signature
My DAZ3D Store
My Free Stuff
My Art @ DeviantART
Profile
Posted: 08 March 2013 09:08 AM   [ Ignore ]   [ # 15 ]
Member
Rank
Joined  2011-09-11
MickyBel - 08 March 2013 08:52 AM
Still solvable.
the issue is that the undershirt mesh does not conform to the base genesis character.
to see this export genesis and the top shirt as individual objs, import them into blender, select the t-shirt and delete that mesh so only genesis and the undershirt mesh are visible, presto clear as day.
the problem is that the undershirt mesh does not conform to the genesis base character, clothing 101.
yes there are hacks to fix the issue, but if daz is going to sell products that dont even conform to clothing 101 standards than we have way bigger issues.
i’m surprised that you did not see this.
thank you, 3d-username
Profile
1 of 3
1
