Digital Art Zone
1 of 2
1
Duplicate IDs on load???
Posted: 10 June 2012 08:44 AM   [ Ignore ]
Member
Avatar
Rank
Joined  2009-09-18
I have noticed recently [perhaps since installing DS4.5] that whenever I load a scene I get a pop up window warning that “Duplicate IDs were found”.  Can anyone shed a light on what this means.  It says I should check the log file, which to me, with my limited [but usually functional] computer knowledge, is about as helpful as looking in my bowl of porridge.rolleyes unless I know what it is I am looking for and what it would mean if I found it.
Profile
Posted: 10 June 2012 09:11 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Much content has been updated, but I do have a script that repairs almost all items - it’s in the index of free scripts linked from my signature.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 10 June 2012 12:30 PM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2009-09-18
Richard Haseltine - 10 June 2012 09:11 AM
Thanks Richard.  I’ve downloaded the script.
Now I’m diving into my old DAZ 2.0 manual to try and figure would where to put the downloaded file and what to do with it.  I’ll let post back here to let you know how I do grin
Profile
Posted: 10 June 2012 02:13 PM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
You can put it anywhere and use File>Merge to load it, or you can put it in something like \DAZ 3D\Studio\My Library\Scripts (or wherever your content is installed to, in the scripts folder), find that folder in the Content Library (under DAZ Studio Formats), right click on the script (it won’t have a proper thumbnail) and from the menu select make custom action - that will add it to your Scripts menu. The idea being that you should be able to run the script while looking at the content that needs it.
 Signature
Profile
Posted: 19 August 2012 05:02 PM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2007-12-07
Now using DS4.5 Pro I am getting these duplicate id messages (quite a lot).  Apart from the irritation factor what underlying problem could they cause?
 Signature
Some writings by a friend:
http://www.lizardsofthehost.co.uk/11.html
http://www.lizardsofthehost.co.uk/13.html
http://www.lizardsofthehost.co.uk/7.html
Profile
Posted: 20 August 2012 07:24 AM   [ Ignore ]   [ # 5 ]
New Member
Joined  2011-09-23
I’m sorry but i seem to be missing something here.
If I save any of the part finished scenes I did in older Daz and reopen them I get this error. If I then go to File>merge > the fix script>open to “library files to fix’, the scene (and dynamics within it) are listed but are not highlighted and so cannot be applied. I am on a Mac and do not has a ‘right click’ mouse.
Profile
Posted: 20 August 2012 07:48 AM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2010-09-24
I’d be interested in the solution as well - as I am also getting these errors as well.
 Signature
My Blog
My World of Trexlin website
Profile
Posted: 20 August 2012 02:30 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
The script was written to fix original content files - I’m really not sure what it will do to saved scenes, if you run it on multiple different files referencing the same data files it may correct the corrections and introduce new issues. I might be able to modify it to fix user-file references (the saved scenes) pointing to fixed data files, if they were in .duf format, but I’m not sure how manageable that would be, and I don’t think it would be possible to do something like it with .daz scene files as they can’t be read by a script and don’t have a known format..
 Signature
Profile
Posted: 20 August 2012 07:30 PM   [ Ignore ]   [ # 8 ]
Member
Rank
Joined  2008-10-17
  I have Genesis Bikini, that I had the duplicate ID error, and after reading posts, I reset the download and see that it is version 1.2, which is supposed to be the updated version.
  I installed it, and when I click on the items to load it in, I get the Duplicate ID error. Clicking OK leaves the item frame in the window, with nothing there.
  I ran the script file that Richard uploaded, and ran it on the file (a .dsf). It cranks along and then finihes, and I notice I have the backup file also in the directory. When I open the item to bring it into the scene, I get no Duplicate ID error - just the blank Item frame. Any thoughts?
  As a note, this is a fresh install of 4.5 release. I also reset the Open Toe Pumps content file, and although I get no Duplicate error, I only get the empty item frame.
  What is really bothering me is if this is a problem with 4.5 itself or its install, or the content file. After I installed it, I did try other files and many gave the ID error. I reset downloads and the new installs worked fine. If there is a problem with the install or program, I’d rather not install a ton of content and then find it out. Is anyone else having a similar problem with reset downloads and/or the Fix ID script?
  Any other thoughts?
 Signature
“Live well, Love Much, Laugh Often”
Profile
Posted: 20 August 2012 09:21 PM   [ Ignore ]   [ # 9 ]
Active Member
Avatar
RankRank
Joined  2012-02-04
I’m in a similar boat.
I waited until 4.5 was actually released to avoid this exact situation.
Lost a 2 days “work” to this mess and I doubt I’ll be able to save the scene.
But after applying the script to Fuji hair for Genesis… it seems to be working, saving and loading.
Not a fun couple of days that’s for sure.
Image Attachments
 Signature
“Art is unique and individual and exists beyond the realms inhabited by those who would reduce things to mere measuring.”  ~Cave
http://ippotamus.deviantart.com/
Profile
Posted: 21 August 2012 07:35 AM   [ Ignore ]   [ # 10 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
reelyor - 20 August 2012 07:30 PM
  Any other thoughts?
The script did fix the old bikini for me, and the updated download was working I think. One thing to double check is that you don’t have two copies of
\Data\Umblefugly\GenesisBikini\BikiniTop\BikiniTop
(or the matching Bikini Bottom file) in your content directories as I can imagine that causing an issue.
 Signature
Profile
Posted: 21 August 2012 07:38 AM   [ Ignore ]   [ # 11 ]
Active Member
Avatar
RankRank
Joined  2007-12-07
Yes, but what actual issue does/can having the duplicate id cause?  So far, for me, it has just been the irritant of a dialog box telling me there’s a duplicate id.  Items have loaded and worked without apparent issue.
 Signature
Profile
Posted: 23 September 2012 04:54 AM   [ Ignore ]   [ # 12 ]
Member
Rank
Joined  2008-05-13
I am having the same issue except mine is with the genesis character itself is this the message you are getting. I’ve uninstalled 4.5 and went back to 4.0 and I do not get that message anymore. something is seriosly wrong with this program I don’t think they tested it before releasing it.
Image Attachments
Profile
Posted: 23 September 2012 05:46 AM   [ Ignore ]   [ # 13 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
This isn’t a general issue, so I suspect it’s down to one of the following:
old content did not uninstall correctly, leaving both old and new versions of some file - did you load the .duf or .dsf version of Genesis?
multiple copies of the Genesis data foldrs in different, mapped, content directories
default scene contains content that hasn’t bee, but needs to be, updated.
 Signature
Profile
Posted: 23 September 2012 07:35 AM   [ Ignore ]   [ # 14 ]
Active Member
Avatar
RankRank
Joined  2009-01-09
shadowl - 23 September 2012 04:54 AM
A question: do you have GenX? Because every morph file created by GenX loads with Genesis every single time, if one of those files has an issue, then Genesis itself has the issue. (This only applies if you used GenX to create shaping morphs in the Shaping tab, not for any presets, which don’t load with Genesis but have to be invoked.)
If you click OK on that message, Studio will load Genesis. At that point, you can look at the troubleshooting log file to see which file produces the message. You can either scroll to the end and go backward until you see the duplicate IDs message, or try search and replace; I find scrolling to the end easier because the log file can be fairly large.
Files produced by the recent update to GenX don’t have that problem, and not all of the files produced by the old version have that problem. In my case, I removed the offending file, redid the morph and everything was fine.
If you don’t have GenX or haven’t used it in this way, then hopefully someone else can help you with the issue.
 Signature
VWrangler at deviantArt (NSFW for some images; login required to view those)
Profile
Posted: 23 September 2012 01:13 PM   [ Ignore ]   [ # 15 ]
Member
Rank
Joined  2008-05-13
I have gen x and pretty much everything else for genesis and yes I have the updated gen x for daz 4.5. I also uninstalled the older version when it asked me to when installing 4.5. Why is it when daz realeses a new version they forget about people having worked with older content and why don’t they put a transfer program in or an updater of some kind to avoid these problems. Like an updater that updates the old genesis to the duf format that will eliminate the problem.
Profile
1 of 2
1
