Digital Art Zone
helicopter blades
Posted: 10 June 2012 05:25 AM   [ Ignore ]
New Member
Joined  2006-09-23
does anyone know how to make a morph or how to make blades flex on a helicopter in Carrara (8.5)?
Profile
Posted: 10 June 2012 09:01 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi smile
Do you mean like this :
http://youtu.be/G0AeNwGkO6U
The flexing of the blades is done by making one blade, and adding a morph target (with a bent down shape) to it.
That single blade is then duplicated and rotated to create the complete set of blades, which are then “Grouped”.
By doing it this way,.. you can adjust the morph value in the “Master” blade, and Carrara will adjust the duplicates.
which makes it easier to deal with any adjustments.
By creating a group, you can add a “spin” modifier, (or several at different speeds), to animate the complete group.
Hope it helps. smile
Profile
Posted: 10 June 2012 06:08 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2006-09-23
Yes, that’s what i needed to know
thanks
Profile
Posted: 10 June 2012 06:31 PM   [ Ignore ]   [ # 3 ]
New Member
Joined  2006-09-23
one thing though, how is the bend applied to the blade, i couldn’t figure out how to do this in the modeling room
Profile
Posted: 11 June 2012 03:24 AM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi mhscspo smile
In the Vertex modeller, you’d select your model,.. create a Morph Area,.. and then create a new Morph Target,..
Then Edit that new morph Target,.
Select the blade tip (end), and enable “soft selection”,
Use the move tools “arrows” to reposition the edges / vertices down, to make the blade look droopy.
You can also use the rotate tools to rotate the selected parts if you want to.
but you’re basically adjusting the shape of that model, to create the bent down shape you need.
Once you’re happy with the shape,. Click the “Valid” button.
You can Switch to Animation mode in the vertex modeller,. and test the morph slider, of just jump back into the Assembly room to see what your new morph looks like in action.
you can always go back into the vertex modeller and edit that morph target, and then click “valid” to change it.
Hope it helps smile
Pic to help
Image Attachments
Profile
Posted: 11 June 2012 06:44 AM   [ Ignore ]   [ # 5 ]
New Member
Joined  2006-09-23
Thanks 3dage, you’re a life (modeling):-)!
Profile
