It is my way,
1 select ALL(not figure) on sceane tab
2 ctrl + click camera (or other items)
3 You may select all bones now. check parameter tab >general>
then “Bend, twist, side-side, front back, up-down” one by one, check “gear” as Super Newb said.
yes You can limit off now.
then save the seanes (with the limit off figure), road the seanes.
(otherwise if you load new genesis, it may keeps limit )
If you want to change them perfectly, I seems you should adjust “propatie editor” and save new propertie, just I think so,,)
yeah, I hope Richard (or someone else may be able to) clarify that. too.
