Digital Art Zone
Hexagon Newb Here
Posted: 23 February 2013 11:16 AM   [ Ignore ]
New Member
Joined  2010-04-27
I’m trying to manipulate the v4 model using Hexagon but I’m a total newb at this. I need to expand her lower face from about mid-nose down, but I don’t know how to get everything to expand outward evenly.
Profile
Posted: 23 February 2013 01:05 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2008-01-01
Welcome!
I assume you have brought the model in via the bridge?
Once it is loaded, select in the properties panel, then hit “Symmetry”.  Wait a while until the symmetry panel turns blue - you should see a perpendicular green frame around the figure, showing that the symmetry plane is in the X- axis.  If not, select the X-axis.
Go into vertex select mode and select “soft selection” in the properties panel and select a vert - some verts will turn red.  Adjust the strength and smoothness so that the red verts cover the area you want to move - don’t select right on the centre line.  Now move the vert you have selected and the others will move proportionately.
Hope this explains what you want - if not, ask away:)
Profile
Posted: 23 February 2013 01:50 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2010-04-27
I’ll give it a shot, might take a while to sort all that out. Had Hexagon for like, a day, and yes I bridged the model from Daz
Profile
