Digital Art Zone
Proportional edit?
Posted: 22 February 2013 10:47 AM   [ Ignore ]
Power Member
Avatar
RankRankRank
Joined  2008-03-06
Hi!  I’m sorry for my ignorance, but I’m trying to help someone learn to morph and they use Hexagon, whereas I use Blender.  Doe Hexagon have a feature equivalent to proportional editing?  PE allows you to select a vertex and have it drag the ones around it to varying degrees (pulling the mesh like taffy).
Also, in Blender you can selectively hide geometry and the hidden bits will be unaffected by the PE, making it easier to morph a hood or half of a jacket or shirt.  Is there anything like that?
 Signature
My store at DAZ.
My Deviantart gallery.
Profile
Posted: 22 February 2013 11:25 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
It’s called Soft Selection in Hexagon, and you will find it in the Properties panel on the right.
You can hide geometry in the Scene Tree, but not for parts of objects, unless they are grouped objects.
Profile
Posted: 22 February 2013 11:28 AM   [ Ignore ]   [ # 2 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-06
JimmyC_2009 - 22 February 2013 11:25 AM
Thank you for the prompt response!
So to hide part of an object it would need to be on a group and then the group be hidden?
 Signature
My store at DAZ.
Profile
Posted: 22 February 2013 11:39 AM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
No, if an item has several grouped parts, you can hide each part within a group, same as in DS.  You can hide any item by switching off the little eye icon (same as DS)
You can use the ‘Extract’ tool to remove Geometry from an object, to create a new object, like splitting clothing into different parts for rigging.
Profile
Posted: 23 February 2013 02:47 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2012-12-01
You can also select faces and make them hidden.
Display > Hide Selected Faces (Cmd-B on Mac), or a button on the tool tab.
Profile
Posted: 23 February 2013 02:48 PM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2008-03-06
lexbaird - 23 February 2013 02:47 PM
That’s probably more likely to be useful.  Thank you. grin
 Signature
My store at DAZ.
Profile
