Digital Art Zone
Need a GL 1.3 ?
Posted: 09 June 2012 05:02 AM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2012-06-03
Apparently I need a GL 1.3 something instead of my GL 1.1, is this something that can be downloaded off the Net ? Really hope so, save having to do without the computer for a couple of days to have it put in otherwise….
 Signature
“Those curious locks so aptly twin’d,
Whose every hair a soul doth bind.”
Thomas Carew 1595 ~ 1640
Profile
Posted: 09 June 2012 06:56 AM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
OpenGL is a way of sending 3D information to a video card. Whether your hardware supports OpenGL 1.3 is a function of the hardware itself, and of the drivers - in order to answer the question we need to know what video card or chip set your machine uses.
 Signature
DAZ Studio Frequently Asked Questions
Index of free DAZ Studio scripts and plugins list
Profile
Posted: 09 June 2012 07:01 AM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
Thanks I’ve no idea where would I find that….?
 Signature
Profile
Posted: 09 June 2012 08:32 AM   [ Ignore ]   [ # 3 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
What operating system are you using?
 Signature
Profile
Posted: 09 June 2012 08:47 AM   [ Ignore ]   [ # 4 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
Windows XP Home 32 bit, Firefox/ Explorer….
 Signature
Profile
Posted: 09 June 2012 11:40 AM   [ Ignore ]   [ # 5 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
In Windows 7
Right click on the “Computer” icon, (or go to Start menu / Control panel,... then go to “Device Manager”,. then look at “Display Adapters”
That will tell you the name and model of your Video card.
However,... if you have windows updates enabled, it would find an install the relevant driver for any system devices, so,.. it would seen that your current Video card only supports OpenGL 1.1.
you need a new graphics card to support higher openGL.
If you’re system is a Desktop it’s a ten minute job to “remove and replace” with new hardware.
If it’s a laptop,. It may be more complex, or in many cases, not possible.
More info about your system may help us to offer better advice.
Profile
Posted: 09 June 2012 12:19 PM   [ Ignore ]   [ # 6 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
Thanks I’ve got a desktop Windows XP Home. I do have Windows Updates enabled and yes it is Open GL 1.1. Not a techie at all so is it something that can be downloaded online or does it mean a visit to my computer repair guy ?
Unfortunately I can’t find anything called “Device Manager” or “Display Adapters” in the Control panel….??
Thanks
 Signature
Profile
Posted: 09 June 2012 12:21 PM   [ Ignore ]   [ # 7 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Actually, on XP Windows Update tends to grab the Microsoft driver rather than the chipset maker’s and that offers only OpenGL 1.1 - it’;s better to use the maker’s driver if possible.
 Signature
Profile
Posted: 09 June 2012 12:42 PM   [ Ignore ]   [ # 8 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
Thank you I’ll try to get the fastest one available sorted on Monday. Is there any limit ?
Btw Richard I’ve been wondering why my username is jsma2012 when I wanted Marcus, or if unavailable I usually use Marcuse. Could it have got mixed up in the general changeover ?
 Signature
Profile
Posted: 09 June 2012 12:47 PM   [ Ignore ]   [ # 9 ]
Power Member
RankRankRank
Joined  2004-07-01
this might be of help - link
http://www.intel.com/support/graphics/sb/CS-004662.htm
Profile
Posted: 09 June 2012 01:09 PM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
Thank you !! Unfortunately I’m not a techie so very wary of downloading things I don’t understand. If this is correct which one of these 2 is the right one ?
Image Attachments
 Signature
Profile
Posted: 09 June 2012 01:47 PM   [ Ignore ]   [ # 11 ]
Administrator
Avatar
RankRankRankRank
Joined  2003-10-09
Updated your username - yes, the switch did seem to undo any changes that had been made to the naem first entered, or used the wrong field if there were two - I’m not sure which, or even if there’s some other reason for the issue.
 Signature
Profile
Posted: 10 June 2012 06:32 AM   [ Ignore ]   [ # 12 ]
Power Member
RankRankRank
Joined  2004-07-01
check your PM
Profile
Posted: 10 June 2012 06:56 AM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2012-06-03
Thanks unfortunately completely lost. I’d rather play it safe really and take it over to my computer guy as whenever I’m without it I get serious withdrawal symptoms !  grin
 Signature
Profile
Posted: 10 June 2012 07:08 AM   [ Ignore ]   [ # 14 ]
Power Member
RankRankRank
Joined  2004-07-01
Marcuse - 10 June 2012 06:56 AM
ok - I am the puter guy ( well was for many years )
Skull
Profile
