Digital Art Zone
rerflection coming in blurry for plane geometric shape
Posted: 08 June 2012 07:37 PM   [ Ignore ]
New Member
Joined  2010-04-23
When I use a plane I get low resolution blurry reflections for chrome or glass. When I use a higher polygon count item, the reflections come in clear. I’m not sure why I can’t get clear reflections on the plane? Your help would be greatly appreciated.
Profile
Posted: 08 June 2012 09:00 PM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2006-08-27
Is the effect you’re describing in the final render, or is it in the assembly room?
Profile
Posted: 08 June 2012 09:18 PM   [ Ignore ]   [ # 2 ]
New Member
Joined  2010-04-23
The reflection comes in blurry in the render room.
Profile
Posted: 09 June 2012 03:22 AM   [ Ignore ]   [ # 3 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
Hi Hunterdon1 smile
In Carrara, you actually need to set an option to Enable “Blurry reflections” in the reflection shader,
the default setting is Not blurry. (which is also faster)
Can you post an image of what you’re seeing, and also an image of your shader tree, with the reflection settings.
See example :
Image Attachments
Profile
