Digital Art Zone
91 of 100
91
The Feh, Meh, Bah Dragons munched my Classic Car Complaint Thread
Posted: 15 March 2013 08:28 AM   [ Ignore ]   [ # 1351 ]
Addict
Avatar
RankRankRankRank
Joined  2005-10-07
Woolyloach - 15 March 2013 08:00 AM
It’s Friday, Friday! cheese And you’ve gotta get down on Friday! tongue laugh tongue rolleye raspberry
Didn’t sleep well last night, but still feeling mostly OK today.  Neck is bothering me a lot so I’m considering coughing up cash to go for a nice massage (not the naughty kind!!).  Going to be in the 80s today, wheeeeeee! cool smile
I’m glad I can sleep in tomorrow, I swear, I need to catch up on my snoozing!  This old loach needs his rest.. downer
Debug, debug, debug today.  Quite a challenging problem to solve, guess that’s why I get the big bucks.. blank stare
a soak in a hot tub or hot bath (with epsom salts) might help loosen the neck tension.
or something more aroma therapeutic?
 Signature
♥ cake ♥ π  kiss  ♥  ♫  ♥
Profile
Posted: 15 March 2013 08:28 AM   [ Ignore ]   [ # 1352 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
Misty Whisky - 15 March 2013 08:10 AM
Rareth - 15 March 2013 07:52 AM
Misty Whisky - 15 March 2013 07:50 AM
Rareth - 15 March 2013 07:39 AM
Misty Whisky - 15 March 2013 07:30 AM
Rareth - 15 March 2013 07:26 AM
Misty Whisky - 15 March 2013 07:18 AM
ESPRESSOOOOOOH javajavajavajava smile
what to do today?
converting configuration screengrabs from 24 T1 cards into an excel spreadsheet.
Sounds exciting, yes?
and the LIU cards and alert reports.  i’m gonna make it pretty!
screen shots? the data can’t be retrieved programatically in a usable format?
i can only get the ascii text via a serial port, and i would have to wait for a tech to do it all for me - i’m not in the union can’t touch the pretties.
not so bad, I’m using OCR from adobe acrobat.
i’m making an access database and an entry form, actually it’s going to be faster to just type in the info.  will need a verify data entry form, too.  yep. job security, lol.
first i have to identify all the fields needed.
shouldn’t be that many..  but then its been a couple years since I had to configure a T1
oh, you’re familiar with the configuration speak?
if i show the fields list, would you critique?  i’m almost complete, ... i think.
sure I can take a look at it..
Thanks smile
lessee. This is just for the LIU info
Route-24: label text site to site MUX
#00 RW - not sure what this means? | Not sure
LIU: string -2412-40
Transmit Options:label text
Frame Format: string
Line Code: string
Equalization: string - there’s an ‘ft’ here, unit of measure?
Clock Synch: string
Maintenance Options: label text
Loopback: boolean
Xmt test pattern: boolean
LIU Signal Generation: label text
Bit Byte Clock: string
Receive Code: string
Code to Dumb Unit: string
Trunk Processing Time: string
CircitID: string
-there’s a new column here, I can’t tell which label block these next 2 should be under? Transmit options? | yes can have internal or external clock syncing
Ext Clock: string
Clock Sync: string
LIU Card Data: label text
Product Rev: string
FW Rev: string
Serial Number: string
Issue Number: string
:date/timestamp
looks pretty good
 Signature
http://rarethdigitalmusings.blogspot.com/
http://rareth1966.deviantart.com/gallery/
Profile
Posted: 15 March 2013 08:30 AM   [ Ignore ]   [ # 1353 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
what to do today?
Thanks smile
Line Code: string
Clock Synch: string
Loopback: boolean
CircitID: string
Ext Clock: string
Clock Sync: string
Product Rev: string
FW Rev: string
:date/timestamp
Channel cards
CH: integer
Model: string
Rev: string
SerialNumber: string
RDL ? - don’t know what this means.
Options: label text
Mode of Operation: string
Receive Gain: string ‘dB’
Transmit Gain: string ‘dB’
Trunk Processing: string (a dropdown list? says IDLE, don’t know other options)
Receive Data/Code: string (dropdown?)
Loopback: boolean
2713 Loopback: boolean (enabled/disabled)
2713 Timeout: boolean (enabled/disabled)
Transmit A Bit: string
Circuit ID: string
Status: label text
says A on the next line.  is that the status? assuming A means active.  Status: boolean
RX: integer
TX: integer
2713 Detect: boolean
Mode: label text
Type: string
NORM ?  -it just says NORM on a line by itself?
Lock: boolean
24 Channels. one to many. LIU to Channels
after this it gets confusing, doh
yeah it does get confusing, most are set and forget, and after the compnay I used to work for grew ginormously, the network engineers took over the wan/lan side of things, all I had to deal with were servers.
 Signature
Profile
Posted: 15 March 2013 08:56 AM   [ Ignore ]   [ # 1354 ]
Addict
Avatar
RankRankRankRank
Joined  2005-10-07
Rareth - 15 March 2013 08:30 AM
what to do today?
Thanks smile
Line Code: string
Clock Synch: string
Loopback: boolean
CircitID: string
Ext Clock: string
Clock Sync: string
Product Rev: string
FW Rev: string
:date/timestamp
Channel cards
CH: integer
Model: string
Rev: string
Options: label text
Loopback: boolean
Circuit ID: string
Status: label text
RX: integer
TX: integer
Mode: label text
Type: string
Lock: boolean
so there’s a 4wire to 4wire. and a 4wire to 2wire.  i hope this clicks in my brain before the espresso wears off.  i haven’t felt this awake all week.
 Signature
Profile
Posted: 15 March 2013 09:06 AM   [ Ignore ]   [ # 1355 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
well like I said its been a few years, and I’m a hands on visual type person.  labels and text in a forum doesn’t quite put it in context for my brain to process.  and based on what google has spit out, there’s not much “user” configuration of the LIU to do.
 Signature
Profile
Posted: 15 March 2013 09:24 AM   [ Ignore ]   [ # 1356 ]
Power Member
Avatar
RankRankRank
Joined  0
Misty Whisky - 15 March 2013 08:28 AM
That sounds reasonable too, as long as I propped my hurt foot up out of the hot water. smile
 Signature
My bloggity blog: http://the-serpents-fang.blogspot.com/
My DeviantArt site: http://theserpentsfeather.deviantart.com/
My red Room Authors Page: http://redroom.com/member/edward-averill
Profile
Posted: 15 March 2013 09:37 AM   [ Ignore ]   [ # 1357 ]
Addict
Avatar
RankRankRankRank
Joined  2005-10-07
Rareth - 15 March 2013 09:06 AM
oh, i didn’t mean to put you out.  I can reference a few manuals or bother a tech.
Thanks though.
It’s always a pleasure to see your cute avatar.  soooo kyoooot.  kiss
 Signature
Profile
Posted: 15 March 2013 09:43 AM   [ Ignore ]   [ # 1358 ]
Active Member
Avatar
RankRank
Joined  2006-08-19
Misty Whisky - 15 March 2013 09:37 AM
Thanks though.
oh its ok, internal lan stuff I know fairly well (routers and switches) as well as ethernet card config.. but basicaly I’m a Server Admin person, (windows, unix. linux doesn’t matter I can manage them) .
 Signature
Profile
Posted: 15 March 2013 09:43 AM   [ Ignore ]   [ # 1359 ]
Addict
Avatar
RankRankRankRank
Joined  2005-10-07
Woolyloach - 15 March 2013 09:24 AM
you can’t wash your foot?  what about that iodine stuff they use in hospitals?
worries about infection.
i understand the contract employee/no insurance/diabetic dilemma, haz the same problem.
 Signature
Profile
Posted: 15 March 2013 10:25 AM   [ Ignore ]   [ # 1360 ]
Addict
Avatar
RankRankRankRank
Joined  2005-10-07
omg, i think i finally found the Laurell K Hamilton my friend was talking about.  She didn’t find a “book” on editing that started her career, she went to an intensive workshop on editing.  grr grrr lol.
http://www.sfsite.com/11a/lh187.htm
so wired on espresso, bing bing bing ricochet
 Signature
Profile
Posted: 15 March 2013 10:28 AM   [ Ignore ]   [ # 1361 ]
Power Member
Avatar
RankRankRank
Joined  0
Misty Whisky - 15 March 2013 09:43 AM
Fortunately the skin isn’t broken on the foot, but because of the swelling I need to keep it iced down when at home, so putting a swollen foot into a hot tub wouldn’t be too good.  That’s why I figured a nice massage, focus on the neck and shoulders. smile
Yeah - no insurance+diabetes = suckage. downer At least most of my supplies are inexpensive.  I just need to stay healthy enough to work, so I can pay off bills and save some for the next stupid emergency. blank stare
 Signature
Profile
Posted: 15 March 2013 12:14 PM   [ Ignore ]   [ # 1362 ]
Addict
Avatar
RankRankRankRank
Joined  2005-10-07
FRIDAYY Yayys!!!
keep the espresso coming, lol.  gotta do some stuff and get it done!!
i ordered that self-editing book, worse comes to worse i’m down the 11 dollars.  and taking to heart some of the tips from the LKH interview.
And ordered Brave.  Saw KK’s princess wip and made me want to see the movie.
d/l the Realpaint demo to give it a serious test drive.
when i get home also gonna d/l the Hexagon and try out it’s dxf capabilities.  i’ve been wanting to design a font and turn it into props.
no utube, tvtropes this weekend, sidetracks me into wasting a whole weekend. keeps me up passed my bedtime and then too tired to do anything the next day. serious!
picking up a visagiftcard on the way home.  3 weekends of mm left.
phew, feeling lil dizzy.  such a thing as too much caffeine?
some serious caching issues today.  every other post turns me over to the broken login page.
 Signature
Profile
Posted: 15 March 2013 12:29 PM   [ Ignore ]   [ # 1363 ]
Administrator
Avatar
RankRankRankRank
Joined  2006-03-19
Brave is a good movie. We have it in 3D
 Signature
ARTCollaborations Store on DAZ3D
Profile
Posted: 15 March 2013 12:29 PM   [ Ignore ]   [ # 1364 ]
Power Member
Avatar
RankRankRank
Joined  2003-10-09
Woolyloach - 15 March 2013 07:48 AM
tjohn - 14 March 2013 02:09 PM
Woolyloach - 14 March 2013 07:54 AM
Sure Happy It’s Thursday. blank stare
Cold chicken fajita taco for breakfast and a diet Coke.  Digestive system hating on me for something I ate yesterday.  Didn’t get a lot of writing done last night.  Foot faintly achy.  Runny nose due to allergies.  Neck sore from sleeping funny, what little sleep I managed to get last night.  Don’t feel like working, wish I were back in my little writers cave, asleep.  I’m bored, tired, and filled to the brim with a listless ennui. blank stare blank stare
Mehhhhhhhhhhhhhhhhhhhhhhhhhh.
But I did get to use the term “listless ennui” in a sentence! cheese
Wooly, did you have a chance to catch this? I mean it’s not like I need the approval of others…oh hell, who am I fooling, of course I do. red face
http://www.daz3d.com/forums/viewthread/17130/P1300
I missed it before but I saw it now - great work!!! LOL LOL cool smile
Thankee!
Listless ennui?
Is there any other kind? An energetic ennui? smile
I was scared listless once…no wait, that was something else. red face
 Signature
This is not my “second childhood”. I’m not finished with the first one yet.
If you find yourself bored out of your gourd, I have an art gallery here (warning: tiny bits of nudity)
http://www.renderosity.com/mod/gallery/browse.php?username=tjohn
Profile
Posted: 15 March 2013 12:38 PM   [ Ignore ]   [ # 1365 ]
Power Member
Avatar
RankRankRank
Joined  0
Misty Whisky - 15 March 2013 12:14 PM
FRIDAYY Yayys!!!
Sounds like a bizzy buzzy dizzy day! big surprise big surprise
Too much caffeine will definitely give you that bzzzzzzzzzzzz feeling.. ugh.  But coffee is a good idea! smile
Brave sounds like fun, maybe I’ll rent it this weekend.
Back to debug, test, and reading! cool smile
 Signature
Profile
91 of 100
91
