I still seem to stumble on the most basic things:
I wanted to test out the “Reflect Me” mirrors and set up a simple test scene.
Test 1:
-open start scene with Genesis
- place Cube 10m “Primitive” in Scene
- place Base Ueber Environment 2 Light with quality settings 4 in scene.
- place random mirror object in scene ( I used AC_RMStandMirror from “Reflect Me”)
In the test render I noticed that Genesis and the Mirror are light as expected but instead of the cube walls showing white in the mirror they are just black.
Test 2:
- place “Plane” 10m “Primitive” in Scene as ground
- place “Plane” 10m “Primitive” in Scene as back wall, z translate - 450, x rotate 90
- place “Plane” 10m “Primitive” in Scene as front wall, z translate 600, x rotate 90
In the test render I noticed that the front wall reflected in the mirror is black will the front wall is white.
I made a second test render to show the scene from an angle top view while looking at the front wall.
The front wall turned out to be completly black.
It seems the inside and the back of objects does not have the color of the outside or the front side.
Was this always like that?
Is there a simple setting to make the inside of cubes and the backside of surfaces also use the same color as the outside and the front?
Example:
In zbrush I just have to toggle on double sided. In vue it seems the outside and the inside color are the same by default when placing primitives into the scene.
