Hi
I’m having issues with the MDD file format for Carrara
When importing a MDD file into 3ds max I was getting an error where some of the vertices in the mesh would not animate they were just staying in the start position so I thought I’d check if the problem was due to Max or Carrara by exporting a MDD from Carrara then importing it back in again.
Every time I do this however I get a message that says “an error has occurred while executing import”
I’m using the 8.5 beta is this likely to be the cause of the import error? Or am I just doing something else wrong. What is the procedure for importing MDD’s in Carrara?
