Digital Art Zone
Hexagon crashes very often
Posted: 07 February 2013 09:57 AM   [ Ignore ]
New Member
Joined  2010-06-09
I like the Hexagon user interface very much, it´s intuitive and not overloaded with windows. I would like the sofware even more if I could trust that my work is not destroyed by crashes. It seems that when you start doing “advanced” operations, hexagon gets enough of it and shuts down. Maybe it´s eating memory, I don´t know. Why don´t DAZ try and find out, and release an update. I think 2.5.1.79 has been around for a quite a while now.
One of my favorite actions is to create tubing by drawing a spline curve and a circle, and then create a sweep surface. I import these tubes into Deep Exploration where I have CAD models of lab instruments. It´s just that the CAD models do not always include the tubing , or you need to adjust the tubing because you move components around. Hexagon is the perfect companion to D.E., if it weren´t for the crashes.
I´m have a Dell Precision laptop with windows 7, 64-bits and 12 GB of memory. Deep Exploration never complains about the power, but Hexagon gets annoyed by something.
Please, DAZ, do some troubleshooting and fix the crash issue. I would rather pay for a working software, then have an almost free software that doesn´t work. I´m sure that a lot of people agree on that.
Thank you.
Profile
Posted: 07 February 2013 10:17 AM   [ Ignore ]   [ # 1 ]
Power Member
Avatar
RankRankRank
Joined  2010-12-18
Well the problem is that a lot of people DON"T have problems. I am one of the people that does have regular issues, and not even with advanced operations. So you have to go the route of documenting when it crashes etc etc if you ever expect any results from Daz.
Just saying things don’t work, won’t get them to budge.
But again, I understand, Hexagon is really unreliable for me except if I’m just making a genesis morph. But something as simple as making a slice into a simple cube crashes. *sigh*
Profile
Posted: 07 February 2013 11:18 AM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2006-11-17
Hi DidrikB,
The latest version of Hexagon does have various issues.  I would first suggest some steps to try to find where the problem lies.
1. If Hexagon has crashed, there is the possibility that the configuration file as become corrupted. So first, open Hexagon and “File-> User Resources-> Reset all”. Then restart Hexagon. (sometimes, even resetting Hexagon will not be enough, as the configuration file itself may required manually deleting. Hexagon does create a new config file on re-start).
2. There can be problems due to the OpenGL optimization. The setting for that is in “Edit-> Preference editor” -> “3D display-> Advanced-> OpenGL optimization”. Change the setting to “No optimization”
3. The next problem can come from attempting to export objects while there is dynamic geometry active (although that was supposed to be fixed. I have seen reports stating it can still cause issues)
So for example, after you create your tubing, before you export to .obj file, select the object then go to the lower right hand side window “Dynamic Geometry” and click on the little lightening bolt, which will collapse the DG.
If you do not use the dynamic geometry, you may be best, in the dynamic geometry window drop down settings, set it to “No DG”, so you do not forget to collapse the DG.
Profile
Posted: 11 February 2013 04:21 AM   [ Ignore ]   [ # 3 ]
New Member
Joined  2010-06-09
Thanks for valuable tips, Steve. I think it worked to reset all preferences and also remove OpenGL optimization.
Before that Hexagon consistently crashed when I tried to edit a dynamic geometry, made by Surface extrude from two lines.
Collapsing the dynamic geometries when you are ready and then saving quickly can be wise.
I´m also running in XP compatible mode, this seemed to reduce the number of crashes. So I guess that Hexagon is maybe not fully compatible with Windows 7 64-bit.
Profile
Posted: 11 February 2013 11:36 AM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2006-11-17
DidrikB - 11 February 2013 04:21 AM
It was fully compatible, as I use V2.1 on win7 64 without any major issues.
When DAZ made the latest update, it was mainly to get better compatibility for MAC, and for the latest DS bridge. Unfortunately, that brought in problems, as I found it less stable and more buggy than previous versions on my win7 64 setup.
Profile
Posted: 20 February 2013 01:51 PM   [ Ignore ]   [ # 5 ]
New Member
Joined  2013-02-20
Hi to all!
I’m here new. I like very much Hexagon because it’s simple & contains understable icons to meshing. It’s importan for me because I’m not so good in English. smile)
I have also issues with very often crashing during meshing. I created hair then I got crash a many times. My effort around the hairystile was lost. :(
I’ve read these tips from Steve, I will try fix this problem with crashing. I’ve spent today a whole day in searching of non-crashed 3D program that is similar to Hexagon, but it’s not that! smile))
I would like to buy this program because it’s not so expensive, but I don’t have any experiences with online paying. :/
Greetings,
Tomislaw.
Profile
Posted: 03 March 2013 08:19 PM   [ Ignore ]   [ # 6 ]
Member
Avatar
Rank
Joined  2004-07-28
Hexagon crashes alot. I’m running win7 64bit. I would very much like to go back to the 2.1 version but I can’t reset that it only gives me the current release. Anyway the program crashes every time I try to use tesselation tools. I have tried the recomended settings in this thread but it doesn’t work for me.
Profile
Posted: 04 March 2013 05:47 AM   [ Ignore ]   [ # 7 ]
Member
Rank
Joined  2006-11-17
Samanthie - 03 March 2013 08:19 PM
On the old DAZ site, there was a download page for the various previous versions, but that appears to be no longer available. You could e-mail support to see if earlier versions are available.
Be aware, the serial for the latest version does not work for previous versions.
Profile
Posted: 04 March 2013 10:32 AM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2004-07-28
Steve athome - 04 March 2013 05:47 AM
Thanks Steve, I have sent in a support ticket to see it Daz can do that for me. I found an old copy on cd but file is corrupted and will not run. I did find the old serial number though so I really hope they will reset it.
Profile
Posted: 08 March 2013 03:34 PM   [ Ignore ]   [ # 9 ]
Member
Avatar
Rank
Joined  2004-07-28
Just got a response to my request for prior release download. No dice, Daz doesn’t make prior releases available. The tools I need to function are the tesselation tools and the program crashes every time.
Profile
Posted: 08 March 2013 05:12 PM   [ Ignore ]   [ # 10 ]
New Member
Joined  2010-03-24
hi i have troubles with hexagon crashing too. i find it works better with local redraw deselected.it tents to cash for these reasons the most trouble i have is extruding (works better with smoothing) and if i loose good topology.  or loose symmetry
Profile
