Digital Art Zone
Bug issue with C8.5
Posted: 07 June 2012 06:56 PM   [ Ignore ]
Member
Avatar
Rank
Joined  2004-12-01
So been playing with Gen in the new beta release see image below.  A changed the ears to elf type and added aldoria hair, if you look closely the hair is raping around the ears.  Is there a work around or is this something that is known issue or does it need to be reported as a bug.
Image Attachments
Profile
Posted: 07 June 2012 09:49 PM   [ Ignore ]   [ # 1 ]
Administrator
Avatar
RankRankRankRank
Joined  2007-11-06
Here’s the solution for this problem in DAZ Studio—I don’t have C8.5 so I can’t say if it’s the same.
When you apply a morph to Genesis a corresponding morph is created in the hair if the morph is set to autofollow.  You need to display hidden morphs in the hair and dial back the auto-generated morph for the elf ears.
 Signature
FastGrab Alert Thread
Non-Genesis Items with Metadata
Plugin Version Numbers for DS 4.5
Updated Genesis Products
Products In Zips
Proud member of the Bald Wizards Club
Profile
Posted: 08 June 2012 04:37 AM   [ Ignore ]   [ # 2 ]
Member
Avatar
Rank
Joined  2004-12-01
thx I will try and see if I can figure that out.
Profile
Posted: 08 June 2012 04:49 AM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2004-12-01
Anyone know where to find the hidden morphs in Carrara as mentioned above.  I went to vertex model area and found the morph but cant get it to change.
Profile
Posted: 08 June 2012 05:52 AM   [ Ignore ]   [ # 4 ]
Power Member
Avatar
RankRankRank
Joined  2004-08-24
I think the morphs for the hair should be accessed through the “Parameters” panel, instead of the Vertex modeller.
Profile
Posted: 11 June 2012 08:40 AM   [ Ignore ]   [ # 5 ]
Member
Avatar
Rank
Joined  2004-12-01
3DAGE - 08 June 2012 05:52 AM
I did find the other morphs mentioned above, but I could not change the parameter it was like disabled as far as being able to change it.
Profile
