I find if I save an installment (for example a dress) in a new directory and then attach it (Add a Base Directory) in Daz 4.5 Pro it works like any other figure.
After I have created the Poser Companion files and put then in the same directory I have now a self-sufficient directory that can be attached both in Daz and Poser. Works like a charm!
But to keep the size down as much as possible I would like to delete the original .duf file. Or is there some caveats to using the DSON generated .duf file to open inside Daz? Are the original and the new DSON .duf file exactly alike?
I don’t want to build up a large external library of 10,50 or 100 GB and later find out that I have done something wrong (for example when I change computer).
