Digital Art Zone
1 of 2
1
Genesis Tights
Posted: 31 January 2013 01:50 PM   [ Ignore ]
Active Member
Avatar
RankRank
Joined  2010-10-10
Some tights for Genesis.
http://www.sharecg.com/v/67190/view/21/DAZ-Studio/Genesis-Tights
Image Attachments
 Signature
Wendy
My freestuff: http://www.sharecg.com/pf/full_uploads.php?pf_user_name=Wilmap
My Deviant Art Gallery:  http://wilmap2.deviantart.com/
Profile
Posted: 31 January 2013 01:51 PM   [ Ignore ]   [ # 1 ]
Active Member
Avatar
RankRank
Joined  2007-12-07
Thanks, they look pretty good!
 Signature
Some writings by a friend:
http://www.lizardsofthehost.co.uk/11.html
http://www.lizardsofthehost.co.uk/13.html
http://www.lizardsofthehost.co.uk/7.html
Profile
Posted: 31 January 2013 02:27 PM   [ Ignore ]   [ # 2 ]
Active Member
Avatar
RankRank
Joined  2010-01-23
Great stuff as always! Thanks.
Profile
Posted: 31 January 2013 04:39 PM   [ Ignore ]   [ # 3 ]
Member
Avatar
Rank
Joined  2011-04-25
Thank you! This is only the second item I have downloaded from you and am having the exact same problem. It doesn’t install properly (or I’m retarded) It tells me that a certain .dsf file is missing. I extract it all to My Library but it’s a no go, even when I go looking for the files manually. What am I doing wrong?
 Signature
My Deviantart account
Profile
Posted: 31 January 2013 06:17 PM   [ Ignore ]   [ # 4 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
interesting.  I’m not getting that error Saiyaness.  Are you sure it’s not a Duplicate ID error?  I fix those with a script, it actually fixes the file.  And if it is a DSF, can you get the file name and path?
 Signature
My DeviantArt Galleries
My ShareCG Gallery
OPENSUBDIV Testing and Discussion
3Delight Surface and Lighting Thread
Profile
Posted: 31 January 2013 07:04 PM   [ Ignore ]   [ # 5 ]
Active Member
Avatar
RankRank
Joined  2007-12-07
The texture path issue is down to a duplicated folder name in the zip - just cut/paste the contents of the \Runtime\textures\Pusey Designs\Underwear\Underwear folder up one level (i.e, drop the bottom-most underwear .... sorry, had to say that! wink)
 Signature
Profile
Posted: 31 January 2013 07:11 PM   [ Ignore ]   [ # 6 ]
Addict
Avatar
RankRankRankRank
Joined  2012-04-07
nm ... getting the threads mixed up. The solution worked for another file I was having a few problems with. tx
 Signature
A couple of tutorial re-ups for those wanting them.
Making skins [basic start]
Unpacking Zip Folders [i.e. how to deal with a gazillion folders if not using DIM]
Profile
Posted: 31 January 2013 07:13 PM   [ Ignore ]   [ # 7 ]
Addict
Avatar
RankRankRankRank
Joined  2012-04-07
wancow - 31 January 2013 06:17 PM
I get both of those errors too. There is one more folder that could be included in the upload as far as I know however can’t say that it’s made any difference not having it either ... but then maybe I just don’t know what I’m missing lol ...
 Signature
Profile
Posted: 31 January 2013 07:19 PM   [ Ignore ]   [ # 8 ]
Member
Avatar
Rank
Joined  2011-04-25
Hmm..so I did a manual install, which I usually do and should just always do…and it worked…except NOW I’m getting the Duplicate ID error. But who cares - they work! So thank you all and thanks again Wilmap! Been looking for freebie stockings for ages!
 Signature
Profile
Posted: 31 January 2013 07:27 PM   [ Ignore ]   [ # 9 ]
Addict
Avatar
RankRankRankRank
Joined  2012-04-07
I was coming back to edit but decided to just add another post. It has occurred to me that some of our various error messages from anybody’s products might be that there are 4 or 5 various D/S4.x out there.
I haven’t tried this yet in 4.0 which is where they’re intended to be for sure and certain.
I have found 4.5 tends to give duplicate error messages even though I can’t find the duplication so don’t know what it’s talking about except that maybe it’s not reading the file as 4.0 would. Just an idea.
At any rate, they work and thank you very much Wilmap grin
 Signature
Profile
Posted: 01 February 2013 02:38 AM   [ Ignore ]   [ # 10 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
I have re-uploaded the file with the textures in the correct place.
I only use DS4 so I have no idea why these errors are occurring for some people. Sorry I can’t help with this problem.
 Signature
Wendy
Profile
Posted: 01 February 2013 08:59 AM   [ Ignore ]   [ # 11 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
There is a script for DuplicateIDs that will fix Wendy’s base file.  I get duplicate IDs on all her stuff, but that’s a simple thing to fix so long as you have the script.
It’s by Richard Hasseline and can be found here:
http://www.daz3d.com/forums/viewthread/293/
 Signature
My ShareCG Gallery
Profile
Posted: 01 February 2013 10:30 AM   [ Ignore ]   [ # 12 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
But why do you get duplicate ID errors?
Is it something I’m doing wrong or just because they are made in DS4?
 Signature
Wendy
Profile
Posted: 01 February 2013 11:24 AM   [ Ignore ]   [ # 13 ]
Active Member
Avatar
RankRank
Joined  2007-01-04
It’s because your using DS4.0 to make them, the files are in the WIP JSON format that 4.0 uses, rather than the “finished” DSON format that we use in 4.5, the older format isn’t completely compatible with DS4.5 which is what causes the errors.
 Signature
**shuffles of with a new headache** tongue wink
Profile
Posted: 01 February 2013 11:25 AM   [ Ignore ]   [ # 14 ]
Active Member
Avatar
RankRank
Joined  2010-10-10
I see, thanks.
Not something I can do anything about then, as I am not going to use DS4.5 to make these clothes, because a lot of people then wouldn’t be able to use them.
 Signature
Wendy
Profile
Posted: 01 February 2013 11:35 AM   [ Ignore ]   [ # 15 ]
Addict
Avatar
RankRankRankRank
Joined  2011-12-10
Wendy, it might be helpful to put that script link in the readme of your stuff.  It fixes the error instantly in the base file, so it becomes a non-issue.
 Signature
My ShareCG Gallery
Profile
1 of 2
1
