Hint: automatic redirect for old forum with firefox addon
PaulSWPaulSW Posts: 0
I often do a search on the old forums but don't want to always change forum.daz3d.com to forumarchive.daz3d.com manually.
Here is a solution I found for my firefox which works great without editing hostfiles etc.
Download:
https://addons.mozilla.org/en-US/firefox/addon/redirector/
Add a new redirect in the addon settings:
Description: DAZ Forum Redirect (or whatever description you like)
Example URL: http://forum.daz3d.com/viewtopic.php?t=180260&sid=747540fd78f1631d0a953979f68ccd3a
(this is only to check if redirect works)
Include Pattern: http://forum.daz3d.com/(.*)
Redirect To: http://forumarchive.daz3d.com/$1
Pattern Type: Regular Expression
Unescape matches: off
Escape matches: off
Enable: on
Now you can save the pattern or test it. Works easy and nice in the background.
Also all your old forum bookmarks will now work again.
  • T JaimanT Jaiman Posts: 540
    edited June 2012
    WooHoo! Thanks! That saves me a lot of fiddling, drudgery, and delay.
    Makes googling the old forums a realtime thing again.
    Works perfectly. :coolsmile:
    Post edited by T Jaiman on
  • GranvilleGranville Posts: 345
    Wow. It works perfectly - Thanks
  • adamr001adamr001 Posts: 22
    Download:
    Escape matches: off
    Enable: on
    You know what would be epic? Could you expand this plugin to change the
    postimages/origimage_1_3096345.png
    code to read
    http://forumarchive.daz3d.com/postimages/origimage_1_3096345.png
    ? Do that and inline images would work...
  • frank0314frank0314 Posts: 10,626
    That would be great if it did.
  • VaskaniaVaskania Posts: 5,920
    code to read
    Yes please!
  • ThinMickThinMick Posts: 0
    edited June 2012
    Example URL: postimages/origimage_1_3398831.jpg
    Include pattern: ^postimages/(.*)
    Redirect to: http://forumarchive.daz3d.com/postimages/$1
    If you click 'Test pattern', it says:
    The pattern ^postimages/(.*) matches example URL postimages/origimage_1_3398831.jpg, and would redirect you to url: http://forumarchive.daz3d.com/postimages/origimage_1_3398831.jpg
    Unfortunately, because the screwed up images don't render as links, it doesn't do anything useful.
    Post edited by ThinMick on
  • CherokeeCherokee Posts: 292
    I haven't been able to get this to work.
    Unfortunately, because the screwed up images don't render as links, it doesn't do anything useful. Really? it durn well ought to... :(
    It does a redirect on click rather than a rewrite on load, so if nothing gets clicked, there's no change. Since the former images show up as unprocessed html tags... Yeah. Doesn't do anything to them.
  • AndyBerlinAndyBerlin Posts: 73
    edited July 2012
    Thanks! This works very well.
    A solution to show most of the images (except product images from the old store and ArtZone Galleries) and to repair some formatings is the extension FoxReplace.
    I have made a description on my new Homepage. There is also a first substitution for the import in FoxReplace. I hope that helps for some of the problems with the old forum.
    Post edited by AndyBerlin on
