I know,,Patience 55,, the product view and file view are not connected with^^;
it must need,,, I think.
then,,old bolock,,
it is because,, the default meta-data of handy poze is not imagine the case.
you use these poze with the Sadie or V4 etc.
So if you want to show the Handy for genesis when you select Sadie,,
first You need to set Sadie meta-data, and set Compatibility base,,(declared as) “I am Sadie Fae” in content DB editor.
(I do not know, Sadie Fae has meta-data already,, but may be not,,,)
then you need to set compatiblity Handy for genesis poze files with Sadie too..
Smart Content just filter compatibility with and base,, they do not think,,
if this poze can be useful for other generation figure,, or not,, never,,
they work , just as meta-data discirbed ^^;
so you can set pozes compatibility with Prop too.. Smart Content can not understand,,
the prop has no hand or not ^^;
