Digital Art Zone
How to “fully” use imported .OBJ?
Posted: 28 January 2013 09:31 AM   [ Ignore ]
Member
Rank
Joined  2012-06-14
I downloaded a gun in .obj format that when unzipped created a .mtl. a .obj, and a subdir called “Texture”. When I imported the .obj I got the object but no texture.
I did point to the obj using “Other Imported Formats” and it at least shows the Texture subdir but nothing else.
Do I have to move the Texture dir somewhere, or do I copy the contents somewhere, or what?
Also, I noticed that the hand grip is supposed to be a cut out area but is actually all filled in. Any thoughts?
The gun in question is from Turbosquid: http://www.turbosquid.com/3d-models/aile-strike-gundam-o-3d-model/494100
Thanks
Profile
Posted: 28 January 2013 10:25 AM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2005-08-15
I just downloaded this OBJ, and it is a mess.  I sent it to Hex, and it has a lot of trinagles, and several ‘non-manifold edges’, and I don;t think you will ever get it to work properly in either DS or Poser.  The LWO one may work better, if you have a program that can open them.
Profile
Posted: 28 January 2013 11:08 AM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2012-06-14
So it is what it is then. Thanks.
Profile
Posted: 28 January 2013 11:25 AM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Yeah…grab the LWO package, instead of the OBJ.  In it is the 3ds version,
Use this http://www.sharecg.com/v/47407/View/10/Software-and-Tools/PropViewer-3.2  to view the 3ds file.  Then in Propviewer, Weld and fix normals.  Then export as an obj or pp2…that will fix the ‘no cutout’ and a couple of other geometry problems.  Then import it, size it and manually apply the diffuse colors…
The ‘black’ is really a dark gray with the value 50 50 50, the blue is 0 40 80 and the metal is the same as the black.  Specular color for the black is 26 26 26 and for the metal it’s 51 51 51…the texture map is applied to the bump channel on the metal material…]
Jimmy…yeah, it’s a rather poor obj conversion…the LWO and 3DS versions are much better.
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 29 January 2013 01:11 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2012-06-14
Wow…thank you!
Profile
Posted: 03 February 2013 10:42 AM   [ Ignore ]   [ # 5 ]
Member
Rank
Joined  2012-06-14
Just wanted to post a followup - thank you again. I’ve been having loads of fun mucking about with Sharecg and other sites I found. And thank you for pointing me to the Propviewer utility - very handy!
Profile
