Digital Art Zone
RENDER ISSUES
Posted: 27 January 2013 06:18 PM   [ Ignore ]
Member
Rank
Joined  2012-12-29
i just started having issues at the rendering stage. (Possibly due to antiquated hardware.)
Previously I was able to render stills, but now (at the half-way point), the process stops with a message that informs me that there is not enough memory to complete the render process.
If I had a better idea of what was wrong…or how to go about solving the problem- at least until I can replace my hardware with something newer- that would help.
My operating systems are XP (desktop) and Vista (laptop).
Profile
Posted: 27 January 2013 07:09 PM   [ Ignore ]   [ # 1 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
dash2128 - 27 January 2013 06:18 PM
Full system specs for each machine…CPU, RAM, video card…
 Signature
1432 old posts
My ShareCG gallery.
Just because something costs a lot, doesn’t mean it’s the best…
It just means it’s expensive.
Profile
Posted: 27 January 2013 07:46 PM   [ Ignore ]   [ # 2 ]
Member
Rank
Joined  2012-12-29
Desktop specs: Sad:
Hewlett-Packard HP Pavilion
MD Sempron (tm) Processor
3400+
1.80 GHz, 1.93 GB of RAM
Windows XP
32-bit
Laptop specs:
Toshiba Satellite L505D
AMD Athlon (tm) X2 Duel-Core QL- 65 2.10 GHz
3.00 GB RAM
32-bit operating system
Right now, I’m just trying to produce stills. I was hoping that what I had could at least do that much till i upgraded.
I also wouldn’t mind knowing what kind of system i should plan for when considering what to get in order to efficiently run Daz and Bryce when I get a new system.  I never planned on using software like Daz when I purchased my 2 present systems, the newest being…maybe 4 or 5 years old.
Profile
Posted: 27 January 2013 08:28 PM   [ Ignore ]   [ # 3 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Forget trying to run 4.5 on the desktop…just not going to happen.  At 2 GB of RAM with what looks to be a 7+ yr old low end processor, it doesn’t have enough to load XP and the program with enough left over to load a model (maybe untextured) and textures, let alone a simple scene.
The laptop should get you at least a simple scene,...but not much more.
Four or more cores, i5 or higher (or AMD PILEDRIVER series), with 8 GB or more RAM, dedicated Nvidia or AMD graphics (needed for UI, but not rendering)...with a 64 bit version of Windows.
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 27 January 2013 08:54 PM   [ Ignore ]   [ # 4 ]
Member
Rank
Joined  2012-12-29
Thanks for the information.
I actually got a couple dozen stills rendered before I started having problems, so I figured I could run on what I had for awhile. This weekend the trouble began, and I suspected that I was not going to get as far as I thought.
Looks like I’ll need to start planning for a major upgrade.
(Hope I can import my products onto a new system after I set it up. I’ve already got a lot of purchases.)
ONE QUESTION: If I upgrade the RAM on the 3.00 GB (RAM) laptop, would that help until I upgrade?
Profile
Posted: 27 January 2013 09:18 PM   [ Ignore ]   [ # 5 ]
Addict
Avatar
RankRankRankRank
Joined  2007-09-13
Yes, but the most you can do is 4 GB, which would give you between 2.25 and 3.0 GB usable…as Windows will reserve the top 1 GB for its own use.
 Signature
1432 old posts
My ShareCG gallery.
Profile
Posted: 27 January 2013 10:14 PM   [ Ignore ]   [ # 6 ]
Member
Rank
Joined  2012-12-29
That’s good to know, though. Thank you again for your help.  !!!!
Profile
